Ana içeriğe geç
BRCK v1 Modem Replacement
Neye ihtiyacın var
  1. BRCK v1 Modem  Replacement, Top Cover: adım 1, 1 resimden 1.
    • Place the face of the device showing BRCK face up.
    FixBot'a Sor
    Yorum Ekle
  2. BRCK v1 Modem  Replacement: adım 2, 1 resimden 1.
    • Remove the four screws(4mm hex head) on the corners of the device with a Hex 2.0 Screwdriver.
    FixBot'a Sor
    Yorum Ekle
  3. BRCK v1 Modem  Replacement: adım 3, 1 resimden 1.
    • Remove the top cover.
    FixBot'a Sor
    Yorum Ekle
  4. BRCK v1 Modem  Replacement, Modem: adım 4, 1 resimden 1.
    • Cut the black zip tie holding the modem down.
    • Caution By cutting the zip tie, you void any manufacturer warranty you may have on the device.
    FixBot'a Sor
    Yorum Ekle
  5. BRCK v1 Modem  Replacement: adım 5, 1 resimden 1.
    • Remove the connection located on the edge of the modem.
    FixBot'a Sor
    Yorum Ekle
  6. BRCK v1 Modem  Replacement: adım 6, 2 resimden 1. BRCK v1 Modem  Replacement: adım 6, 2 resimden 2.
    • Slightly lift the modem to reveal the brown ribbon connector and metal connection plate, located on the bottom of the modem.
    FixBot'a Sor
    Yorum Ekle
  7. BRCK v1 Modem  Replacement: adım 7, 3 resimden 1. BRCK v1 Modem  Replacement: adım 7, 3 resimden 2. BRCK v1 Modem  Replacement: adım 7, 3 resimden 3.
    Bu adımda kullanılan alet:
    • Using your tweezers, gently push on the metal plate and slide it down toward the base of the modem to release the locking mechanism.
    • Lower the plate and gently pull the ribbon out of the face plate.
    • Caution Be extremely gentle while preforming this step. The ribbon is brittle and prone to breaking if bent too much. Make sure you go slowly so that you do not damage the device.
    FixBot'a Sor
    Yorum Ekle
  8. BRCK v1 Modem  Replacement: adım 8, 2 resimden 1. BRCK v1 Modem  Replacement: adım 8, 2 resimden 2.
    • Remove the modem from the device.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Jeret Buerger
501 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 12-3, Lancaster Spring 2015 Cal Poly, Team 12-3, Lancaster Spring 2015 üyesi
CPSU-LANCASTER-S15S12G3
3 Üyeler
14 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 20
Her zaman: 486
