Ana içeriğe geç
BRCK v1 Modem MicroSD Card Replacement
Neye ihtiyacın var
    1. BRCK v1 Modem MicroSD Card Replacement, Top Cover: adım 1, 1 resimden 1.
      • Place the face of the device showing BRCK face up.
      FixBot'a Sor
      Yorum Ekle
    2. BRCK v1 Modem MicroSD Card Replacement: adım 2, 1 resimden 1.
      • Remove the four screws(4mm hex head) on the corners of the device with a Hex 2.0 Screwdriver.
      FixBot'a Sor
      Yorum Ekle
    3. BRCK v1 Modem MicroSD Card Replacement: adım 3, 1 resimden 1.
      • Remove the top cover.
      FixBot'a Sor
      Yorum Ekle
    1. BRCK v1 Modem MicroSD Card Replacement, Modem: adım 4, 1 resimden 1.
      • Cut the black zip tie holding the modem down.
      • Caution By cutting the zip tie, you void any manufacturer warranty you may have on the device.
      FixBot'a Sor
      Yorum Ekle
    2. BRCK v1 Modem MicroSD Card Replacement: adım 5, 1 resimden 1.
      • Remove the connection located on the edge of the modem.
      FixBot'a Sor
      Yorum Ekle
    3. BRCK v1 Modem MicroSD Card Replacement: adım 6, 2 resimden 1. BRCK v1 Modem MicroSD Card Replacement: adım 6, 2 resimden 2.
      • Slightly lift the modem to reveal the brown ribbon connector and metal connection plate, located on the bottom of the modem.
      FixBot'a Sor
      Yorum Ekle
    4. BRCK v1 Modem MicroSD Card Replacement: adım 7, 3 resimden 1. BRCK v1 Modem MicroSD Card Replacement: adım 7, 3 resimden 2. BRCK v1 Modem MicroSD Card Replacement: adım 7, 3 resimden 3.
      Bu adımda kullanılan alet:
      • Using your tweezers, gently push on the metal plate and slide it down toward the base of the modem to release the locking mechanism.
      • Lower the plate and gently pull the ribbon out of the face plate.
      • Caution Be extremely gentle while preforming this step. The ribbon is brittle and prone to breaking if bent too much. Make sure you go slowly so that you do not damage the device.
      FixBot'a Sor
      Yorum Ekle
    5. BRCK v1 Modem MicroSD Card Replacement: adım 8, 2 resimden 1. BRCK v1 Modem MicroSD Card Replacement: adım 8, 2 resimden 2.
      • Remove the modem from the device.
      FixBot'a Sor
      Yorum Ekle
    1. BRCK v1 Modem MicroSD Card Replacement, Modem MicroSD Card: adım 9, 3 resimden 1. BRCK v1 Modem MicroSD Card Replacement, Modem MicroSD Card: adım 9, 3 resimden 2. BRCK v1 Modem MicroSD Card Replacement, Modem MicroSD Card: adım 9, 3 resimden 3.
      • With your tweezers, slide the metal face plate to release the locking mechanism.
      • Lift the face plate and carefully remove the microSD card.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Jeret Buerger
501 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 12-3, Lancaster Spring 2015 Cal Poly, Team 12-3, Lancaster Spring 2015 üyesi
CPSU-LANCASTER-S15S12G3
3 Üyeler
63 adet Kılavuz yazıldı
1Rehber Yorum
Can my brck connect if it does not have the sim card and the SD card from the manufacturer?
Sigmore Govera - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 22
Her zaman: 501
