Ana içeriğe geç
BaByliss-Expert Plus 2000 Hairdryer Thermal Fuse Replacement
Neye ihtiyacın var
    1. BaByliss-Expert Plus 2000 Hairdryer Thermal Fuse  Replacement, Thermal Fuse: adım 1, 2 resimden 1. BaByliss-Expert Plus 2000 Hairdryer Thermal Fuse  Replacement, Thermal Fuse: adım 1, 2 resimden 2.
      • Before disassembly, unplug the device.
      • Make sure the device was not on for the last 10 minutes, because it might still be hot.
      • Unscrew the two screws on the handle with the spanner screwdriver.
      FixBot'a Sor
      Yorum Ekle
    2. BaByliss-Expert Plus 2000 Hairdryer Thermal Fuse  Replacement: adım 2, 2 resimden 1. BaByliss-Expert Plus 2000 Hairdryer Thermal Fuse  Replacement: adım 2, 2 resimden 2.
      • Pull the case in opposite directions.
      • You might need a prying tool if the black components don't come out easily.
      FixBot'a Sor
      Yorum Ekle
    3. BaByliss-Expert Plus 2000 Hairdryer Thermal Fuse  Replacement: adım 3, 1 resimden 1.
      • Unscrew the remaining two screws inside the handle with the Phillips screwdriver.
      FixBot'a Sor
      Yorum Ekle
    4. BaByliss-Expert Plus 2000 Hairdryer Thermal Fuse  Replacement: adım 4, 3 resimden 1. BaByliss-Expert Plus 2000 Hairdryer Thermal Fuse  Replacement: adım 4, 3 resimden 2. BaByliss-Expert Plus 2000 Hairdryer Thermal Fuse  Replacement: adım 4, 3 resimden 3.
      • Push the inner components out of the handle.
      FixBot'a Sor
      Yorum Ekle
    5. BaByliss-Expert Plus 2000 Hairdryer Thermal Fuse  Replacement: adım 5, 2 resimden 1. BaByliss-Expert Plus 2000 Hairdryer Thermal Fuse  Replacement: adım 5, 2 resimden 2.
      • Locate the thermal fuse.
      • Test the thermal fuse for continuity using the multimeter.
      • Make sure the multimeter is set to 200 ACV and bring the probes toward thermal fuse.
      • The circuit is closed and properly functioning if the multimeter displays varying numbers.
      • The circuit is open if the multimeter displays non-varying numbers or no numbers at all.
      FixBot'a Sor
      Yorum Ekle
    6. BaByliss-Expert Plus 2000 Hairdryer Thermal Fuse  Replacement: adım 6, 1 resimden 1.
      • To replace the thermal fuse, use the prying tool to extract the object.
      • To remove it, wedge it back and forth until it comes free.
      • You don't need to take out the gold piece under the thermal fuse.
      FixBot'a Sor
      Yorum Ekle
    7. BaByliss-Expert Plus 2000 Hairdryer Thermal Fuse  Replacement: adım 7, 1 resimden 1.
      • Replace the old thermal fuse by a new one.
      FixBot'a Sor
      Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
2Kılavuz Yorumları
Does anybody know what is the small silver cylinder next to the thermal fuse? It is inline with the neutral AC from the handle switch, looks like it could be a diode or possibly a resistor, though it really resembles nothing I have seen before. My inoperable unit shows no continuity through this device either direction, so I presume it is bad….but I have no idea what to replace it with!
Richard H - Yanıt Paylaş
This is the thermostat, not the “thermal fuse’’ !!
ilko M - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 7
Son 7 gün: 55
Son 30 gün: 243
Her zaman: 12,639
