Ana içeriğe geç
Back Cover Replacement
Neye ihtiyacın var
  1. Back Cover Replacement, Back Cover: adım 1, 1 resimden 1.
    • Power off Zoomer Dino Boomer before disassembly.
    • Remove the eight 9.3mm Phillips #1 screws.
    FixBot'a Sor
    Yorum Ekle
  2. Back Cover Replacement: adım 2, 2 resimden 1. Back Cover Replacement: adım 2, 2 resimden 2.
    • Turn dinosaur over and hold upright.
    • Use the spudger to pry apart the back cover from the remainder of the Zoomer Dino Boomer.
    • Be gentle while removing the back cover. The back cover of the Zoomer Dino Boomer is still connected to the electronic system by a wire.
    FixBot'a Sor
    Yorum Ekle
  3. Back Cover Replacement: adım 3, 3 resimden 1. Back Cover Replacement: adım 3, 3 resimden 2. Back Cover Replacement: adım 3, 3 resimden 3.
    Bu adımda kullanılan alet:
    • Disconnect the wire that connects the back cover of the dino to the main circuit board by carefully pulling on the orange wire connector with tweezers.
    • Remove back cover.
    • If you are having difficulty removing the connector from its socket, push in the small tabs on the side of the connector with the tweezers. This step may take some work.
    • Do not damage the wires or circuit board.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Desiree DesJardins
452 İtibar
2 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 16-1, Wollert Fall 2015 USF Tampa, Team 16-1, Wollert Fall 2015 üyesi
USFT-WOLLERT-F15S16G1
3 Üyeler
10 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 30
Her zaman: 1,045
