Ana içeriğe geç
Back Panel Removal
Neye ihtiyacın var
  1. Back Panel Removal, Battery: adım 1, 1 resimden 1.
    • Power down the computer and unplug the power adapter.
  2. Back Panel Removal: adım 2, 1 resimden 1.
    • Flip the laptop upside down. Locate the two latches on both sides of the battery.
  3. Back Panel Removal: adım 3, 3 resimden 1. Back Panel Removal: adım 3, 3 resimden 2. Back Panel Removal: adım 3, 3 resimden 3.
    • Slide the latch on the right outwards, releasing the lock. The latch stays unlocked once moved.
    • Simultaneously slide the latch on the left outwards while pulling the battery towards you.
    • Do not touch the metal connectors on the laptop and the battery.
  4. Back Panel Removal, Back Panel Removal: adım 4, 1 resimden 1.
    • Remove the single captive screw on the back panel with your Phillips #1 screwdriver.
  5. Back Panel Removal: adım 5, 2 resimden 1. Back Panel Removal: adım 5, 2 resimden 2.
    • Pry the removal tab up. You will feel and hear the first clip release, popping up slightly.
    • Work your way around the border of the panel, releasing the rest of the clips.
    • Once all clips are released, lift the cover up and pull towards you.
Sonuç
To replace the back panel, follow the steps in reverse.
2 farklı kişi bu kılavuzu tamamladı.
Austin Bons
1.131 İtibar
8 adet Kılavuz yazıldı
Ekip
UC Davis, Team 2-2, Oliver Fall 2016 UC Davis, Team 2-2, Oliver Fall 2016 üyesi
UCD-OLIVER-F16S2G2
5 Üyeler
10 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 12
Son 30 gün: 90
Her zaman: 8,111
