Ana içeriğe geç
Back Panel
Neye ihtiyacın var
  1. Back Panel, Back Panel: adım 1, 1 resimden 1.
    • Flip the laptop so that the back is facing upwards.
    • Locate the small screw on the back that holds the "L" shaped panel.
    • Using a 0 Phillip Screwdriver (4.0x4.7mm sized screw), unscrew the screw. It will not become detached from the panel but it will allow you to remove the back panel.
  2. Back Panel: adım 2, 3 resimden 1. Back Panel: adım 2, 3 resimden 2. Back Panel: adım 2, 3 resimden 3.
    • Using a plastic opening tool, pry the back panel from the computer, going all the way around it.
    • This will take a good amount of force and you will hear clicking noises as you snap each of the connections out of place.
  3. Back Panel: adım 3, 1 resimden 1.
    • Once the back panel is completely removed you will have access to the RAM and many other connections in the computer.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 5
Her zaman: 531
