Ana içeriğe geç
Backpack Base Replacement
Neye ihtiyacın var
    1. Backpack Base Replacement, Base: adım 1, 2 resimden 1. Backpack Base Replacement, Base: adım 1, 2 resimden 2.
      • Turn the backpack inside out.
      FixBot'a Sor
      Yorum Ekle
    2. Backpack Base Replacement: adım 2, 1 resimden 1.
      • Seam rip the binding along the bottom rectangle of the backpack.
      • Discard the ripped panel of burlap.
      • Make sure to set aside the lining fabric before discarding the burlap.
      FixBot'a Sor
      Yorum Ekle
    3. Backpack Base Replacement: adım 3, 3 resimden 1. Backpack Base Replacement: adım 3, 3 resimden 2. Backpack Base Replacement: adım 3, 3 resimden 3.
      • Iron the base panel of the polyester lining fabric.
      • Place the lining fabric on top of the desired fabric.
      • Using a ruler and rotary cutter, cut an identical rectangle.
      • Carefully round the corners of your desired fabric rectangle to match the shape of the liner.
      • Use caution when ironing the base panel.
      FixBot'a Sor
      Yorum Ekle
    4. Backpack Base Replacement: adım 4, 3 resimden 1. Backpack Base Replacement: adım 4, 3 resimden 2. Backpack Base Replacement: adım 4, 3 resimden 3.
      • Pin the liner and new fabric panel together, so that the 'right sides' of the fabric are facing outwards.
      • Set your machine to the longest stitch length (usually 5 mm), and the loosest thread tension.
      • Not every machine will allow you to adjust the thread tension. If yours allows you to adjust it, set it to zero.
      • Sew the layers together with a 1/4" seam allowance.
      FixBot'a Sor
      Yorum Ekle
    5. Backpack Base Replacement: adım 5, 3 resimden 1. Backpack Base Replacement: adım 5, 3 resimden 2. Backpack Base Replacement: adım 5, 3 resimden 3.
      • Pin the lining and new fabric base so that it is centered on the thick side of the backpack.
      • Using a zipper foot, sew the new fabric base and liner to the thick side of the backpack.
      • Be careful to align the corners of the base to the corners of the backpack.
      FixBot'a Sor
      Yorum Ekle
    6. Backpack Base Replacement: adım 6, 3 resimden 1. Backpack Base Replacement: adım 6, 3 resimden 2. Backpack Base Replacement: adım 6, 3 resimden 3.
      • Make note of how much larger the fabric base is in comparison to the remaining 3 sides of the backpack.
      • Using a contrasting-colored thread, hand-sew along the corners of the base fabric.
      • Tighten the contrasting threads to bunch up the corners until they fit snug into the corners of the backpack.
      • Pin the remaining 3 sides of the base with to the 3 sides of the backpack.
      FixBot'a Sor
      Yorum Ekle
    7. Backpack Base Replacement: adım 7, 3 resimden 1. Backpack Base Replacement: adım 7, 3 resimden 2. Backpack Base Replacement: adım 7, 3 resimden 3.
      • Sew along the remaining three sides.
      • Be extra careful around the corners to avoid any hard creases or folds.
      • Seam-rip the contrasting color thread.
      • Trim down any fabric that exceeds 1/4" seam allowance, particularly around the corners.
      FixBot'a Sor
      Yorum Ekle
    8. Backpack Base Replacement: adım 8, 2 resimden 1. Backpack Base Replacement: adım 8, 2 resimden 2.
      • Turn the backpack right side out.
      • Look along the new seam for any of the stitches that hold the lining and base fabric together, and remove them.
      • Pin the binding around the bottom seam, so that it sandwiches the seam allowance.
      • Allow one end of the binding to remain loose.
      FixBot'a Sor
      Yorum Ekle
    9. Backpack Base Replacement: adım 9, 3 resimden 1. Backpack Base Replacement: adım 9, 3 resimden 2. Backpack Base Replacement: adım 9, 3 resimden 3.
      • Starting with the pinned end of the binding, carefully sew about 1/10" away from the end of the binding.
      • When you reach the loose end of the binding, connect the end that you already sewed with the loose end.
      • Sew both ends together.
      FixBot'a Sor
      Yorum Ekle
    10. Backpack Base Replacement: adım 10, 3 resimden 1. Backpack Base Replacement: adım 10, 3 resimden 2. Backpack Base Replacement: adım 10, 3 resimden 3.
      • Check the inside and out for any flaws or hard creases.
      • Enjoy your newly repaired backpack!
      FixBot'a Sor
      Yorum Ekle
Bitiş Çizgisi
Sheen Patel
181 İtibar
1 Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 6
Son 7 gün: 13
Son 30 gün: 56
Her zaman: 2,267
