Giriş
If the needle in your Badger 105 Patriot airbrush has been damaged or lost, use this guide to replace it. The needle and head control the flow and pattern of paint as it exits the airbrush, and any damage or warpage will cause uneven paint distribution.
Before using this guide, make sure you have located a replacement needle and head set. These can be purchased directly from Badger. This guide will also work with other brands of airbrushes as the internal mechanics of all airbrushes share the same parts and structure.
Make sure to rinse any residual uncured paint from your airbrush before beginning.
No tools are needed for this guide.
Bir başkası bu kılavuzu tamamladı.
