Ana içeriğe geç
Basic Maintenance
Neye ihtiyacın var
  1. Basic Maintenance, Locating the side panel: adım 1, 2 resimden 1. Basic Maintenance, Locating the side panel: adım 1, 2 resimden 2.
    • First, locate the side panel on the far left side of your board.
    • Then, flip your board upside down.
    • Make sure your console is resting on a towel or soft surface, as hard jolts or bumps can cause damage to your board.
    FixBot'a Sor
    Yorum Ekle
  2. Basic Maintenance, Removing the bracket: adım 2, 2 resimden 1. Basic Maintenance, Removing the bracket: adım 2, 2 resimden 2.
    • Now, use your Phillips-head screwdriver to unscrew the two screws holding the bracket on.
    • Then flip your board over and do the same on the other side to remove the second bracket.
    FixBot'a Sor
    Yorum Ekle
  3. Basic Maintenance, Loosening the panel screws: adım 3, 1 resimden 1.
    • Now, locate the three screws at the bottom of the back panel and loosen them approximately two full turns.
    • Make sure to keep screws separate! Always label and separate different screws to avoid confusion when we reassemble the board.
    FixBot'a Sor
    Yorum Ekle
  4. Basic Maintenance, Remove the metal pieces: adım 4, 1 resimden 1.
    • Now flip your board over again so it is right-side-up.
    • Then, remove the seven screws holding the metal piece on with the same screwdriver. There is one screw to the far right of the piece that I could not fit into the photo.
    FixBot'a Sor
    Yorum Ekle
  5. Basic Maintenance, Pull the top off: adım 5, 2 resimden 1. Basic Maintenance, Pull the top off: adım 5, 2 resimden 2.
    • Now, put your hand on the back of the board and lift up and away from the base of the console. Be careful of any wires!
    • Set the top panel next to the base to avoid wires getting tangled and broken.
    FixBot'a Sor
    Yorum Ekle
  6. Basic Maintenance, The inside components: adım 6, 2 resimden 1. Basic Maintenance, The inside components: adım 6, 2 resimden 2.
    • You might notice that a lot of the components inside the lighting board look similar to those of a desktop computer. The power supply, hard drive, RAM, CPU, and cooling system are all in the base of the board.
    • If you have a compressed air can or blower, use that to clean the main components, especially around the CPU and heatsinks, as these can get clogged with dust and debris. If you don't have one of these tools, use a DRY paper towel or tissue to gently wipe down the components.
    FixBot'a Sor
    Yorum Ekle
  7. Basic Maintenance, Re-seating the RAM: adım 7, 2 resimden 1. Basic Maintenance, Re-seating the RAM: adım 7, 2 resimden 2.
    • RAM is good to re-seat every so often, as it helps to maintain clean ports and fast memory speeds.
    • To remove the RAM, press down on the two clips on either side of the stick, then pull up on the RAM to remove it.
    • Once you remove it, you can take your air blower and gently blow off any dust on the connectors and memory cards.
    FixBot'a Sor
    Yorum Ekle
    • Now reverse these steps to reassemble your ETC Ion 1000!
    FixBot'a Sor
    Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
someperson
953 İtibar
2 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 19
Her zaman: 94
