Giriş
The motherboard of the Basis Peak can be replaced to get the device working good-as-new. This guide will show you step by step how to remove the motherboard for replacement. The back plate must be removed to first allow the electronics to be removed from the frame. Following this, several cables must be detached to separate the motherboard from the rest of the electronics.
Neye ihtiyacın var
Flip the watch over and orient it such that the buckle is away from you and the back panel is revealed.
2 farklı kişi bu kılavuzu tamamladı.
