Ana içeriğe geç
Basis Peak Screen Replacement
Neye ihtiyacın var
    1. Basis Peak Screen Replacement, Frame: adım 1, 1 resimden 1.
      • Flip the watch over and orient it such that the buckle is away from you and the back panel is revealed.
      • Maintain this orientation to follow the guide.
      FixBot'a Sor
      Yorum Ekle
    2. Basis Peak Screen Replacement: adım 2, 2 resimden 1. Basis Peak Screen Replacement: adım 2, 2 resimden 2.
      • Remove the four base screws using a size 2 TORX screwdriver to separate the back plate from the frame.
      FixBot'a Sor
      Yorum Ekle
    3. Basis Peak Screen Replacement: adım 3, 1 resimden 1.
      • Disconnect the ribbon cable on the left side of the motherboard by using a spudger.
      FixBot'a Sor
      Yorum Ekle
    4. Basis Peak Screen Replacement: adım 4, 1 resimden 1.
      • Use a spudger and apply pressure to the white plastic wall to the right of the motherboard. Use this to lever the electronics out of the frame.
      • The clips have small lips that you can put the spudger under to get more leverage.
      • Using any of the metal to pry out the electronics may damage some of the wiring. It is crucial to only press on the plastic.
      FixBot'a Sor
      Yorum Ekle
    1. Basis Peak Screen Replacement, Screen: adım 5, 1 resimden 1.
      • Flip over the motherboard complex and gently remove the screen with your fingers.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Steph
101 İtibar
1 Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S4-G4, Julie Spring 2017 UMass Dartmouth, Team S4-G4, Julie Spring 2017 üyesi
UMASSD-JULIE-S17S4G4
4 Üyeler
30 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 30
Her zaman: 550
