Giriş
Over time bathroom faucet knobs crack or age poorly, and the caps loosen and fall off the knobs, creating a space to collect dust and pathogens. This guide will provide step-by-step instructions to help you replace the knobs and caps from the bathroom faucet, maintaining the area free of danger and bacteria. This guide is easy to follow, with no special skills necessary. We have used the “Danco Faucet Remodeling Kit for Delta.”
Before beginning the repair, shut off the water supply to prevent accidental water damage. In this guide, you will find the instructions to shut off the water supply. Now go and make your bathroom faucet look like new again!
Neye ihtiyacın var
Underneath the sink there are two valves that supply water to each knob. Turn off the supply by twisting the valves tightly to the right.
Test that the replacement was done correctly and that the water supply is on by twisting the faucet knobs to the right. Enjoy your new remodeled faucet!
Bir başkası bu kılavuzu tamamladı.
