Giriş
Overtime, bathtub drains become worn and need to be replaced. Some indications that you need a new drain are slow drainage, leaks, corrosion or cracks, a broken stopper, or mineral buildup that cannot be cleaned. This guide provides an easy, safe, and affordable way to replace a bathtub drain on your own.
Standard bathtub drains have a 1.5 inch diameter. If you are unsure about the size of yours, measure before purchasing the new drain cover.
You can find a new drain cover at your local Home Depot; I purchased the Danco EZ Drain Cover. This package includes the EZ Drain Cover and two gaskets.
Bir başkası bu kılavuzu tamamladı.
