Ana içeriğe geç
Batteries in Nikon Coolpix 4600 Replacement
Neye ihtiyacın var
  1. Batteries in Nikon Coolpix 4600 Replacement, Batteries: adım 1, 1 resimden 1.
    • Locate the battery compartment on the bottom right of the camera.
  2. Batteries in Nikon Coolpix 4600 Replacement: adım 2, 2 resimden 1. Batteries in Nikon Coolpix 4600 Replacement: adım 2, 2 resimden 2.
    • While holding the camera with the lens facing toward you, slide the lock button to the right and pull the battery door towards you. The battery door should pop open.
    • If the door does not pop open, gently lift the door using your finger.
  3. Batteries in Nikon Coolpix 4600 Replacement: adım 3, 1 resimden 1.
    • Remove the dead batteries. The easiest way to do this is by turning the camera right side up and gently tapping the lens side of the camera against your hand until they fall out. If this does not work, you can simply pull them out.
  4. Batteries in Nikon Coolpix 4600 Replacement: adım 4, 1 resimden 1.
    • Insert fresh AA batteries into the compartment as demonstrated in the picture to the left. The orientation of the batteries is important to ensure the camera works properly.
    • Close the battery door.
    • Remember to slide the switch back into the lock position.
Sonuç
Reassembly of the camera is the final step in the guide.
Richard
9 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 9-43, Regan Spring 2012 Cal Poly, Team 9-43, Regan Spring 2012 üyesi
CPSU-REGAN-S12S9G43
5 Üyeler
12 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 9
Son 30 gün: 43
Her zaman: 2,791
