Ana içeriğe geç
Battery Blocking
Salt Önkoşul
Bu sadece bir ön koşul kılavuzudur! Bu kılavuz başka bir prosedürün parçasıdır ve tek başına kullanılması amaçlanmamıştır.
Neye ihtiyacın var
  1. Battery Blocking, Unfasten the bottom cable shield: adım 1, 2 resimden 1. Battery Blocking, Unfasten the bottom cable shield: adım 1, 2 resimden 2.
    • Use a Phillips screwdriver to remove the three 1.2 mm screws securing the bottom cable shield to the logic board.
    FixBot'a Sor
    Yorum Ekle
  2. Battery Blocking, Remove the bottom cable shield: adım 2, 3 resimden 1. Battery Blocking, Remove the bottom cable shield: adım 2, 3 resimden 2. Battery Blocking, Remove the bottom cable shield: adım 2, 3 resimden 3.
    Bu adımda kullanılan alet:
    • Use tweezers or your fingers to remove the bottom cable shield.
    FixBot'a Sor
    Yorum Ekle
  3. Battery Blocking, Disconnect the battery: adım 3, 2 resimden 1. Battery Blocking, Disconnect the battery: adım 3, 2 resimden 2.
    • Use a Phillips screwdriver to remove the 1.8 mm screw securing the battery connector to the logic board.
    FixBot'a Sor
    Yorum Ekle
  4. Battery Blocking, Battery connector information: adım 4, 3 resimden 1. Battery Blocking, Battery connector information: adım 4, 3 resimden 2. Battery Blocking, Battery connector information: adım 4, 3 resimden 3.
    • These photos show what the battery connector looks like underneath the logic board. Use these photos as a reference while you safely disconnect the battery.
    • Notice that the battery connector has cantilever springs on the logic board that press against the battery contact pads. Since both the logic board and battery are glued down, you'll need to slide something thin and flexible between the contact points to disconnect the battery.
    FixBot'a Sor
    Yorum Ekle
  5. Battery Blocking, Create a battery blocker: adım 5, 3 resimden 1. Battery Blocking, Create a battery blocker: adım 5, 3 resimden 2. Battery Blocking, Create a battery blocker: adım 5, 3 resimden 3.
    • Cut two 6 mm wide strips from a playing card or cardstock to use as a battery blocker.
    • The strips should be about 4 cm long so you can easily grip them.
    FixBot'a Sor
    Yorum Ekle
  6. Battery Blocking, Insert the card strips: adım 6, 3 resimden 1. Battery Blocking, Insert the card strips: adım 6, 3 resimden 2. Battery Blocking, Insert the card strips: adım 6, 3 resimden 3.
    • Insert the card strips on each side of the battery connector until they stop.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Chayton Ritter
27.020 İtibar
105 adet Kılavuz yazıldı
Ekip
Guide Team Guide Team üyesi
Staff
10 Üyeler
21.380 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 23
Her zaman: 381
