Ana içeriğe geç
Battery Disconnect
Salt Önkoşul
Bu kılavuz yalnızca diğer kılavuzlar için bir ön koşul olarak kullanılmak üzere tasarlanmıştır. Tek başına eksiktir.
Neye ihtiyacın var
  1. Battery Disconnect, Back Cover: adım 1, 1 resimden 1.
    • Before you begin, switch off your phone.
    • Apply a heated iOpener to the back of the phone to loosen the adhesive beneath the back cover. Apply the iOpener for at least two minutes.
  2. Battery Disconnect: adım 2, 3 resimden 1. Battery Disconnect: adım 2, 3 resimden 2. Battery Disconnect: adım 2, 3 resimden 3.
    • Secure a suction handle to the bottom of the back cover, as close to the edge as possible.
    • Lift the back cover with the suction handle to create a small gap between the cover and the frame.
    • Insert an opening pick into the gap.
    • If you have trouble, apply more heat to further soften the adhesive. Follow the iOpener instructions to avoid overheating.
    • Slide the opening pick to the bottom left corner.
  3. Battery Disconnect: adım 3, 2 resimden 1. Battery Disconnect: adım 3, 2 resimden 2.
    • Insert a second opening pick and slide it to the bottom right corner to cut the adhesive.
    • Leave the opening picks in place to prevent the adhesive from resealing.
  4. Battery Disconnect: adım 4, 3 resimden 1. Battery Disconnect: adım 4, 3 resimden 2. Battery Disconnect: adım 4, 3 resimden 3.
    • Insert a third opening pick at the bottom left corner.
    • In the next few steps whilst cutting around the rear camera make sure you only use the tip of the opening pick to avoid smearing the lens or damaging the camera.
    • Start to slide the tip of the opening pick from the bottom left corner along the side of the phone to cut the adhesive.
    • Leave the opening pick in its place at the top left corner to prevent the adhesive from resealing.
  5. Battery Disconnect: adım 5, 2 resimden 1. Battery Disconnect: adım 5, 2 resimden 2.
    • If the adhesive becomes hard to cut it most likely cooled down. Use your iOpener to reheat it.
    • Insert a fourth opening pick under the top left corner of the back cover.
    • Slide the opening pick along the top edge of the phone to cut the adhesive.
    • Leave the opening pick in the top right corner to prevent the adhesive from resealing.
  6. Battery Disconnect: adım 6, 2 resimden 1. Battery Disconnect: adım 6, 2 resimden 2.
    • Insert a fifth opening pick at the top right corner of the phone.
    • Slide the opening pick along the right side to cut the remaining adhesive.
  7. Battery Disconnect: adım 7, 2 resimden 1. Battery Disconnect: adım 7, 2 resimden 2.
    • Lift and remove the back cover.
    • After installing the back cover, apply strong, steady pressure to your phone for several minutes to help the adhesive form a good bond, such as by placing it under a stack of heavy books.
  8. Battery Disconnect, Battery Disconnect: adım 8, 3 resimden 1. Battery Disconnect, Battery Disconnect: adım 8, 3 resimden 2. Battery Disconnect, Battery Disconnect: adım 8, 3 resimden 3.
    Bu adımda kullanılan alet:
    • Use a pair of tweezers to carefully peel the adhesive strip off the mother board and the battery and remove it.
  9. Battery Disconnect: adım 9, 2 resimden 1. Battery Disconnect: adım 9, 2 resimden 2.
    • Use a pair of tweezers to peel the black adhesive strip off the battery connector and fold it out of the way.
  10. Battery Disconnect: adım 10, 2 resimden 1. Battery Disconnect: adım 10, 2 resimden 2.
    • Use a spudger to pry up and disconnect the battery connector.
Sonuç
Dominik Schnabelrauch
231.169 İtibar
682 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
120 Üyeler
19.664 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 4
Her zaman: 21
