Giriş
Prerequisite-only guide! This guide is part of another procedure and is not meant to be used alone.
Use this guide to safely disconnect the battery before beginning repairs on an Early 2020 MacBook Air.
Parçalar
Hiçbir parça belirtilmedi.
If your MacBook is running Big Sur v11.1 or later, disabling Auto Boot may not work. You can proceed normally, but make sure to disconnect the battery as soon as you're inside.
Use a P5 driver to remove the following screws:
Two 7.9 mm screws
Two 7.1 mm screws
Six 2.6 mm screws
Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
Remove the lower case.
Set it in place and press firmly to engage the two hidden clips underneath. You should feel and hear them snap into place.
Peel back the tape covering the battery connector enough to reveal the connector underneath.
