Ana içeriğe geç
Bazic 3003 Battery Replacement
Neye ihtiyacın var
  1. Bazic 3003 Battery Replacement, Bazic Calculator: adım 1, 1 resimden 1.
    • Press the "OFF" button on your Bazic 3003 calculator.
    • Make sure it is powered off before you begin the repair.
    FixBot'a Sor
    Yorum Ekle
  2. Bazic 3003 Battery Replacement: adım 2, 1 resimden 1.
    • Turn your calculator over so the back is facing up.
    FixBot'a Sor
    Yorum Ekle
  3. Bazic 3003 Battery Replacement: adım 3, 1 resimden 1.
    • Use a Phillips #0 screwdriver to remove the 1.0 mm screw from the battery compartment.
    FixBot'a Sor
    Yorum Ekle
  4. Bazic 3003 Battery Replacement: adım 4, 1 resimden 1.
    • Only one button battery is needed for the calculator to function but you can add one or two.
    • Use your fingers or a plastic spudger to remove the battery from the calculator.
    • Insert the new button battery into the slot and push it into place.
    FixBot'a Sor
    Yorum Ekle
  5. Bazic 3003 Battery Replacement: adım 5, 1 resimden 1.
    • Replace the battery door.
    • Use a Phillips #0 screwdriver to replace the screw and secure the battery door.
    FixBot'a Sor
    Yorum Ekle
  6. Bazic 3003 Battery Replacement: adım 6, 1 resimden 1.
    • Push the "On" button on your calculator and check if the buttons work and function properly.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Bryan Reyes
136 İtibar
1 Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 30
Her zaman: 470
