Ana içeriğe geç
Beaded Bracelet Clasp Replacement
  1. Beaded Bracelet Clasp Replacement, Beaded Bracelet Clasp: adım 1, 1 resimden 1.
    • From the left end of the bracelet, string on a crimp bead and one end of the new clasp.
    • Bring the clasp and crimp bead 3 inches from the left end of the string.
  2. Beaded Bracelet Clasp Replacement: adım 2, 1 resimden 1.
    • Loop the left end of the string through the left side of the crimp bead.
  3. Beaded Bracelet Clasp Replacement: adım 3, 1 resimden 1.
    • Push the crimp bead up close to the clasp.
    • Push the crimp bead up as close as you can to the clasp.
  4. Beaded Bracelet Clasp Replacement: adım 4, 2 resimden 1. Beaded Bracelet Clasp Replacement: adım 4, 2 resimden 2.
    • Use the bead crimp tool to squeeze the crimp bead shut.
    • Use scissors to cut off excess string.
  5. Beaded Bracelet Clasp Replacement: adım 5, 1 resimden 1.
    • Bead the bracelet from the right end.
  6. Beaded Bracelet Clasp Replacement: adım 6, 1 resimden 1.
    • After all beads are on, string on a crimp bead and then the other end of the new clasp.
  7. Beaded Bracelet Clasp Replacement: adım 7, 1 resimden 1.
    • Loop the right end of the string through the right side of the crimp bead.
  8. Beaded Bracelet Clasp Replacement: adım 8, 1 resimden 1.
    • Pull on the string to tighten the bracelet.
    • You do not want the beads spread out.
  9. Beaded Bracelet Clasp Replacement: adım 9, 2 resimden 1. Beaded Bracelet Clasp Replacement: adım 9, 2 resimden 2.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Kelly
182 İtibar
1 Kılavuz yazıldı
One Comment
Awesome!! Its very beautiful [|bracelets] each step make this bracelets so easy. Thank you!! Keep it up
daniel - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 8
Son 30 gün: 49
Her zaman: 1,937
