Ana içeriğe geç
Bear 1000 Power Entry Module Replacement
Tıbbi Ekipman
iFixit de, bu onarım kılavuzu da tıbbi cihaz üreticisi tarafından onaylanmış değildir ya da herhangi birinin üreticiyle alâkası yoktur.
Neye ihtiyacın var
  1. Bear 1000 Power Entry Module Replacement, Air and O2 Blender: adım 1, 1 resimden 1.
    • Remove the ribbon cable at the connection on the oxygen blender control board.
    FixBot'a Sor
    Yorum Ekle
  2. Bear 1000 Power Entry Module Replacement: adım 2, 1 resimden 1.
    • Mark the plastic hoses attached to the oxygen blender (so you can put them back on the same way) and then remove.
    FixBot'a Sor
    Yorum Ekle
  3. Bear 1000 Power Entry Module Replacement: adım 3, 1 resimden 1.
    • The air/oxygen blender has two screws close to the control board. Remove them and remove the unit.
    FixBot'a Sor
    Yorum Ekle
  4. Bear 1000 Power Entry Module Replacement, Air and O2 Inlet Manifold: adım 4, 1 resimden 1.
    • Remove the pneumatic and electrical connections labeled.
    FixBot'a Sor
    Yorum Ekle
    • Remove the water trap bowls on the rear of the unit.
    FixBot'a Sor
    Yorum Ekle
  5. Bear 1000 Power Entry Module Replacement: adım 6, 1 resimden 1.
    • Remove the four screws and remove the manifold.
    FixBot'a Sor
    Yorum Ekle
    • Remove the two screws holding the power supply to the manifold.
    FixBot'a Sor
    Yorum Ekle
    • Mark or label the 6 faston connections as to position and remove
    FixBot'a Sor
    Yorum Ekle
    • Mark or label the two wires going to the power switch and remove at the power switch end
    FixBot'a Sor
    Yorum Ekle
    • Using an allen wrench, remove the power cord retaining bracket.
    FixBot'a Sor
    Yorum Ekle
  6. Bear 1000 Power Entry Module Replacement: adım 11, 1 resimden 1.
    • Using an allen wrench, remove the mounting screwa and nuts from the Power Entry Module.
    FixBot'a Sor
    Yorum Ekle
    • After removing the heat shrink tubing, unsolder the two lower wires from the Power Entry Module, noting locations.
    FixBot'a Sor
    Yorum Ekle
    • Solder the wires to the replacement module, covering the joints with heat shrink tubing.
    FixBot'a Sor
    Yorum Ekle
    • Transfer the voltage selector drum from the original module to the replacement and reinstall.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Eli Ferman
607 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S7-G12, Paton Fall 2020 Cal Poly, Team S7-G12, Paton Fall 2020 üyesi
CPSU-PATON-F20S7G12
2 Üyeler
6 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 19
Her zaman: 260
