Ana içeriğe geç
Beats Pill 1.0 Speaker Replacement
Neye ihtiyacın var
  1. Beats Pill 1.0 Speaker Replacement, Removing the Case Screws: adım 1, 3 resimden 1. Beats Pill 1.0 Speaker Replacement, Removing the Case Screws: adım 1, 3 resimden 2. Beats Pill 1.0 Speaker Replacement, Removing the Case Screws: adım 1, 3 resimden 3.
    • Using the spudger, create space between the speaker covers and then remove.
    • On the underside of the device, remove the rubber stand with the BeatsPill logo on it.
    • Using an ESD-safe Phillips #0 screwdriver, remove the four screws that were underneath the rubber stand.
  2. Beats Pill 1.0 Speaker Replacement, Removing Center Cover: adım 2, 3 resimden 1. Beats Pill 1.0 Speaker Replacement, Removing Center Cover: adım 2, 3 resimden 2. Beats Pill 1.0 Speaker Replacement, Removing Center Cover: adım 2, 3 resimden 3.
    • Remove the two screws with a Phillips #0 screwdriver.
    • Slowly remove the center band and two clip rings until the adhesive separates. Sit to the side the clip rings and the center band
  3. Beats Pill 1.0 Speaker Replacement, Separate the Device: adım 3, 3 resimden 1. Beats Pill 1.0 Speaker Replacement, Separate the Device: adım 3, 3 resimden 2. Beats Pill 1.0 Speaker Replacement, Separate the Device: adım 3, 3 resimden 3.
    • Use the spudger to pry the device apart along its seam, starting in the middle.
    • Open the device to separate the front and back panels.
  4. Beats Pill 1.0 Speaker Replacement, Disconnect Speaker Wiring: adım 4, 2 resimden 1. Beats Pill 1.0 Speaker Replacement, Disconnect Speaker Wiring: adım 4, 2 resimden 2.
    • Carefully remove the yellow, red, black, and white wires from the motherboard.
    • Ground yourself when touching the motherboard.
  5. Beats Pill 1.0 Speaker Replacement, Disconnect NFC Sensor Wiring: adım 5, 2 resimden 1. Beats Pill 1.0 Speaker Replacement, Disconnect NFC Sensor Wiring: adım 5, 2 resimden 2.
    • Carefully remove the black and red NFC sensor wires.
  6. Beats Pill 1.0 Speaker Replacement, Disconnect Control Wiring: adım 6, 2 resimden 1. Beats Pill 1.0 Speaker Replacement, Disconnect Control Wiring: adım 6, 2 resimden 2.
    • Carefully remove the control cables (4 black, 1 red).
  7. Beats Pill 1.0 Speaker Replacement, Speaker: adım 7, 2 resimden 1. Beats Pill 1.0 Speaker Replacement, Speaker: adım 7, 2 resimden 2.
    • Using the Phillips #0 screwdriver, unscrew the two screws that holds the speakers down.
  8. Beats Pill 1.0 Speaker Replacement: adım 8, 1 resimden 1.
    • Each speaker is held down by two clips. On the front face of the speaker, push the speaker outward while pushing one of the clips that holds it down to the side. Repeat this on the other speaker and clip. The speakers should pop out.
Sonuç
9 farklı kişi bu kılavuzu tamamladı.
Dylan Cooper Dalrymple
741 İtibar
3 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 5-4, Blackwell Fall 2015 USF Tampa, Team 5-4, Blackwell Fall 2015 üyesi
USFT-BLACKWELL-F15S5G4
4 Üyeler
12 adet Kılavuz yazıldı
10 Yorum
Do you have a link to the speakers that are used for the speaker pill, the current one seems to be broken and I cant find the replacements anywhere
justin perez - Yanıt
Just wanted to add a comment regarding where to find the actual replacement speakers for the Beats Pill 1.0. I quite certain that the over all size of each individual speaker is 1" including the plastic bezel around the speaker. The actual size of the speaker itself is 3/4" and I believe I have found a replacement speaker to use if one of the speakers in your Beats Pill 1.0 gets blown or damaged. Below is the link to the replacement speaker, found on www.partsexpress.com. It looks almost identical to the stock speaker installed in the Pill 1.0, minus the custom bezel around the speaker that is used to secure the speakers inside the Pill.
http://www.parts-express.com/tymphany-pm...
Buying all 4 speakers at once saves you 75 cent compared to the price of buying just a single speaker.
Hope this helps anyone looking for replacement speakers for their Beats Pill 1.0
Brad Shirer - Yanıt
I just got all 4 new speakers to replace the older ones as the rubber rims have all soften and sort of disintegrated/damaged. Only problems with the replacement speakers plastic body are not same as original ones. So the speakers won’t fit the 2 clips, so almost no way to secure the speakers. Probably need to be Super glue.
Victor -
I plugged my speaker in because it needed a charge and the metal piece inside the speaker went into it help
Tanner McKinley - Yanıt
Where can i pay for a new speakers??, help me please…
j.j.g.n - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 6
Son 7 gün: 46
Son 30 gün: 163
Her zaman: 38,719
