Ana içeriğe geç
Beats Solo 3 Headband Replacement
Neye ihtiyacın var
  1. Beats Solo 3 Headband Replacement, Headband: adım 1, 3 resimden 1. Beats Solo 3 Headband Replacement, Headband: adım 1, 3 resimden 2. Beats Solo 3 Headband Replacement, Headband: adım 1, 3 resimden 3.
    • Carefully partially remove the headband cushion cover. Be careful not to rip the two headband eyelets just above the screws on each end of the headband.
  2. Beats Solo 3 Headband Replacement: adım 2, 2 resimden 1. Beats Solo 3 Headband Replacement: adım 2, 2 resimden 2.
    • With the main part of the cover off, pull the head band cover up and out of the metal headband ends, exposing the screws underneath.
  3. Beats Solo 3 Headband Replacement: adım 3, 3 resimden 1. Beats Solo 3 Headband Replacement: adım 3, 3 resimden 2. Beats Solo 3 Headband Replacement: adım 3, 3 resimden 3.
    • Unscrew all four 1.4 mm screws on the right and left ends on the underside of the headband using a T5 Torx screwdriver.
  4. Beats Solo 3 Headband Replacement: adım 4, 1 resimden 1.
    • Pull the metal headband end out from the headband slightly, and disconnect the rubber band from the hook.
  5. Beats Solo 3 Headband Replacement: adım 5, 2 resimden 1. Beats Solo 3 Headband Replacement: adım 5, 2 resimden 2.
    • Remove the inner headband by gently prying the edges and corners.
  6. Beats Solo 3 Headband Replacement: adım 6, 1 resimden 1.
    • Carefully peel up the glued wire in the headband.
  7. Beats Solo 3 Headband Replacement: adım 7, 1 resimden 1.
    • Pull the headband out of the slots gently.
  8. Beats Solo 3 Headband Replacement: adım 8, 1 resimden 1.
    • Put the new headband into the slots carefully.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Joseph Konadu
211 İtibar
1 Kılavuz yazıldı
Ekip
2 Yorum
help when i was putting on the new headband the snap on middle parts fell out and i cant put them back in (the metal connection parts)
koro - Yanıt
same it happen to me as well
Bardo -
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 8
Son 7 gün: 70
Son 30 gün: 297
Her zaman: 10,658
