Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Carefully partially remove the headband cushion cover. Be careful not to rip the two headband eyelets just above the screws on each end of the headband.
With the main part of the cover off, pull the head band cover up and out of the metal headband ends, exposing the screws underneath.
Unscrew all four 1.4 mm screws on the right and left ends on the underside of the headband using a T5 Torx screwdriver.
Pull the metal headband end out from the headband slightly, and disconnect the rubber band from the hook.
Remove the inner headband by gently prying the edges and corners.
4 farklı kişi bu kılavuzu tamamladı.
