Ana içeriğe geç
Beats Solo Pro Side panel Replacement
Neye ihtiyacın var
  1. Beats Solo Pro Side panel Replacement, Extending the Headphones: adım 1, 2 resimden 1. Beats Solo Pro Side panel Replacement, Extending the Headphones: adım 1, 2 resimden 2.
    • Slide the headphones down to extend the hinge.
  2. Beats Solo Pro Side panel Replacement, Prying off the side panel: adım 2, 2 resimden 1. Beats Solo Pro Side panel Replacement, Prying off the side panel: adım 2, 2 resimden 2.
    • Once extended insert a prying the new gap to unclip the panel
    • Once unclipped repeat on the other side of the panel
    • The two clips are towards the top of the panel, as indicated by the location of the metal prying tool in the image.
  3. Beats Solo Pro Side panel Replacement, Sliding out the side panel: adım 3, 2 resimden 1. Beats Solo Pro Side panel Replacement, Sliding out the side panel: adım 3, 2 resimden 2.
    • Slide the panel down and lift away from the headphone just until its separated
    • Don't pull the plastic piece offs there is still cables attached to it
  4. Beats Solo Pro Side panel Replacement, Tightening or replacing: adım 4, 2 resimden 1. Beats Solo Pro Side panel Replacement, Tightening or replacing: adım 4, 2 resimden 2.
    • If needed tighten the PH00 screw(if your side panel has came loose on it own you will need to do this to fix the issue)
    • If you want to replace the side panel you will need to carefully pry the cables out from where they are glued in and glue them in to the new panel(refer to second image)
Sonuç
To reassemble complete steps in reverse:-)
4 farklı kişi bu kılavuzu tamamladı.
HelloMacOS
26.030 İtibar
11 adet Kılavuz yazıldı
Ekip
Repair is War on Entropy Repair is War on Entropy üyesi
Community
25 Üyeler
1.166 adet Kılavuz yazıldı
Bir Yorum
Muchas gracias por tus pasos a seguir.
Yo tengo un problema pero con el tornillo que esta tapado por los cables, al cual no puedo acceder para poderlo apretar contra la tapa exterior.
Alfredo Olvera - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 gün: 27
Son 30 gün: 133
Her zaman: 3,030
