Ana içeriğe geç
Beats Studio First Generation Batteries Replacement
Neye ihtiyacın var
  1. Beats Studio First Generation Batteries Replacement, Identify the Left Speaker Housing: adım 1, 1 resimden 1.
    • The left speaker is the speaker that holds the batteries and does not have the power switch.
    FixBot'a Sor
    Yorum Ekle
  2. Beats Studio First Generation Batteries Replacement, Removing the Battery Cap: adım 2, 3 resimden 1. Beats Studio First Generation Batteries Replacement, Removing the Battery Cap: adım 2, 3 resimden 2. Beats Studio First Generation Batteries Replacement, Removing the Battery Cap: adım 2, 3 resimden 3.
    • Place two fingers on each side of the cap. Press and twist counterclockwise to loosen the cap.
    • Once the cap is loose, simply lift the cap out to reveal the batteries.
    FixBot'a Sor
    Yorum Ekle
  3. Beats Studio First Generation Batteries Replacement, Batteries!: adım 3, 1 resimden 1.
    • Carefully pull the batteries out of their housings. When putting in new batteries, make sure that you place each battery in the correct orientation.
    FixBot'a Sor
    Yorum Ekle
Sonuç
24 farklı kişi bu kılavuzu tamamladı.
Oscar
1.216 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 9-18, Regan Spring 2014 Cal Poly, Team 9-18, Regan Spring 2014 üyesi
CPSU-REGAN-S14S9G18
4 Üyeler
19 adet Kılavuz yazıldı
29Kılavuz Yorumları
hi man you post is help me a lot thank you..God bless you
EL TIO SAM MARS - Yanıt Paylaş
Are u using 4A batteries on this? Please reply ASAP. The 3a batteries won't fit on my beats wireless studio.
Nessa Upzs - Yanıt Paylaş
They are 2 x AAA batteries. This is Beats Studio first generation which are WIRED headphones.
John Coops - Yanıt Paylaş
Help,I'm trying to twist off battery compartment and it's not budging! Should I try and pry off w/screwdriver! Any ideas?
Kathy - Yanıt Paylaş
hello jus curious if u got the cap to come off n how if so? any advice wld b greatly appreciated please n thank u
Randi - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 34
Son 30 gün: 173
Her zaman: 153,735
