Ana içeriğe geç
Beats Studio3 Wireless Battery Replacement
Neye ihtiyacın var
  1. Beats Studio3 Wireless Battery Replacement, Battery: adım 1, 2 resimden 1. Beats Studio3 Wireless Battery Replacement, Battery: adım 1, 2 resimden 2.
    • Use a pointed nylon spudger to remove the center circular panel on the right side of your device.
    • Be gentle while removing this piece as it is glued on with adhesive.
    FixBot'a Sor
    Yorum Ekle
  2. Beats Studio3 Wireless Battery Replacement: adım 2, 2 resimden 1. Beats Studio3 Wireless Battery Replacement: adım 2, 2 resimden 2.
    • Remove the four 3.5 mm screws using a Phillips #0 screwdriver.
    FixBot'a Sor
    Yorum Ekle
  3. Beats Studio3 Wireless Battery Replacement: adım 3, 3 resimden 1. Beats Studio3 Wireless Battery Replacement: adım 3, 3 resimden 2. Beats Studio3 Wireless Battery Replacement: adım 3, 3 resimden 3.
    • Using a pointed nylon spudger, remove the tab located on the inner part of the headband labeled "R."
    • Place the nylon spudger in between the side panels and push inward going from bottom to top to separate both sides of the panel.
    • The panel will pop open after separating.
    FixBot'a Sor
    Yorum Ekle
  4. Beats Studio3 Wireless Battery Replacement: adım 4, 1 resimden 1.
    • Place the nylon spudger underneath the battery, push inward and separate the battery from the inside.
    • Never use sharp tools to pry batteries. Metal spudgers can puncture an unprotected battery, potentially causing a fire.
    FixBot'a Sor
    Yorum Ekle
  5. Beats Studio3 Wireless Battery Replacement: adım 5, 2 resimden 1. Beats Studio3 Wireless Battery Replacement: adım 5, 2 resimden 2.
    • Use a nylon spudger to lift up the glue sticking the wires down.
    • Use a nylon spudger to lift the connector to disconnect the battery.
    FixBot'a Sor
    Yorum Ekle
Sonuç
7 farklı kişi bu kılavuzu tamamladı.
Lourdes Dejesus
240 İtibar
1 Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 7-4, Ryckebusch Spring 2023 UMass Dartmouth, Team 7-4, Ryckebusch Spring 2023 üyesi
UMASSD-RYCKEBUSCH-S23S7G4
3 Üyeler
13 adet Kılavuz yazıldı
4Kılavuz Yorumları
Should the glue be reapplied or is it okay to simply place back on?
Jake Allen - Yanıt Paylaş
the replacement batteries usually come with a gluepad on the back.
The connector its up to you - you risk the chance of the connector coming lose and u have to reopen the headset. But ill take the chance for now, lets see how it holds up without new glue.
seb - Yanıt Paylaş
Tengo una duda mis audífonos la batería esta full de voltaje pero me marca un rojo y no me prenden q podría ser o que solución podría darle
luis m cruz - Yanıt Paylaş
My beats studio 3 proplem was it plink whit when i connect it with the charger, but when i press to start it it blinks full red .
My Qus is .. is the battery are dameged ..?!
Hmam - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 15
Son 7 gün: 99
Son 30 gün: 390
Her zaman: 12,474
