Ana içeriğe geç
Beboncool Wireless Switch Pro Controller Buttons Replacement
Neye ihtiyacın var
  1. Beboncool Wireless Switch Pro Controller Buttons Replacement, Motherboard: adım 1, 1 resimden 1.
    • Use a Phillips #0 screwdriver to remove the seven 5 mm screws from the back of the controller.
  2. Beboncool Wireless Switch Pro Controller Buttons Replacement: adım 2, 2 resimden 1. Beboncool Wireless Switch Pro Controller Buttons Replacement: adım 2, 2 resimden 2.
    • Gently separate the top and bottom halves of the controller.
  3. Beboncool Wireless Switch Pro Controller Buttons Replacement: adım 3, 2 resimden 1. Beboncool Wireless Switch Pro Controller Buttons Replacement: adım 3, 2 resimden 2.
    • Use a Phillips #0 screwdriver to remove the two 5 mm screws holding the joystick motherboard in place.
  4. Beboncool Wireless Switch Pro Controller Buttons Replacement: adım 4, 1 resimden 1.
    • Carefully move the bumper buttons out of the way.
  5. Beboncool Wireless Switch Pro Controller Buttons Replacement: adım 5, 2 resimden 1. Beboncool Wireless Switch Pro Controller Buttons Replacement: adım 5, 2 resimden 2.
    • Use a Phillips #0 screwdriver to remove the 5 mm screw holding the motherboard in place.
    • Remove the motherboard.
  6. Beboncool Wireless Switch Pro Controller Buttons Replacement, Buttons: adım 6, 2 resimden 1. Beboncool Wireless Switch Pro Controller Buttons Replacement, Buttons: adım 6, 2 resimden 2.
    Bu adımda kullanılan alet:
    • To remove the alphabetic buttons, remove the translucent silicone cover.
    • Use tweezers or your fingers to remove the buttons.
    • Pushing a button from below will elevate them enough to easily grab them.
  7. Beboncool Wireless Switch Pro Controller Buttons Replacement: adım 7, 2 resimden 1. Beboncool Wireless Switch Pro Controller Buttons Replacement: adım 7, 2 resimden 2.
    • To remove the directional buttons, first remove the translucent silicone cover. Then, use tweezers or your fingers to remove the button pad.
    • As with the alphabetic buttons, push on the buttons from below, then grab them.
Sonuç
Tayah Appel
529 İtibar
5 adet Kılavuz yazıldı
Ekip
Casper College, Team 1-3, Lareau Spring 2023 Casper College, Team 1-3, Lareau Spring 2023 üyesi
CASC-LAREAU-S23S1G3
3 Üyeler
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 13
Her zaman: 199
