Ana içeriğe geç
Bed boards Replacement
Neye ihtiyacın var
  1. Bed boards Replacement, Bed Boards: adım 1, 2 resimden 1. Bed boards Replacement, Bed Boards: adım 1, 2 resimden 2.
    • Remove the matress from the bed.
  2. Bed boards Replacement: adım 2, 1 resimden 1.
    • Remove the box spring from the bed.
  3. Bed boards Replacement: adım 3, 1 resimden 1.
    • Remove the old boards using the Phillips #1 screwdriver.
  4. Bed boards Replacement: adım 4, 1 resimden 1.
    • Using your measure tape, measure the old boards and write down the measurements.
  5. Bed boards Replacement: adım 5, 1 resimden 1.
    • Find some wooden boards with 2x2 measures (width) and with the length you already measured.
  6. Bed boards Replacement: adım 6, 2 resimden 1. Bed boards Replacement: adım 6, 2 resimden 2.
    • Screw in the replacement boards.
  7. Bed boards Replacement: adım 7, 3 resimden 1. Bed boards Replacement: adım 7, 3 resimden 2. Bed boards Replacement: adım 7, 3 resimden 3.
    • Put your box spring and mattress back and you are done.
Sonuç
To assemble your bed boards just follow the steps provided in the order given and your bed boards will be ready to go.
Bir başkası bu kılavuzu tamamladı.
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 10
Son 30 gün: 57
Her zaman: 1,453
