Ana içeriğe geç
Behringer BCD3000 Disassembly
Neye ihtiyacın var
  1. Behringer BCD3000 Disassembly, Behringer BCD3000 Disassembly: adım 1, 1 resimden 1.
    • Unplug from all cables
  2. Behringer BCD3000 Disassembly, opening the sides: adım 2, 2 resimden 1. Behringer BCD3000 Disassembly, opening the sides: adım 2, 2 resimden 2.
    • unscrew two Phillips screws on each side of the BCD3000
    • If the screws sit too tight, you can use the extension for better torque
  3. Behringer BCD3000 Disassembly, loosening the top part: adım 3, 2 resimden 1. Behringer BCD3000 Disassembly, loosening the top part: adım 3, 2 resimden 2.
    • unscrew another two Phillips screws on each side
  4. Behringer BCD3000 Disassembly: adım 4, 3 resimden 1. Behringer BCD3000 Disassembly: adım 4, 3 resimden 2. Behringer BCD3000 Disassembly: adım 4, 3 resimden 3.
    • Lift the upper control part.
    • Be careful, there are still some cables connected to the lower section.
    • Disconnect the cables by walking them out of their sockets.
  5. Behringer BCD3000 Disassembly: adım 5, 1 resimden 1.
    • Remove the upper part completely.
  6. Behringer BCD3000 Disassembly: adım 6, 1 resimden 1.
    • Disconnect the two cables from the lower section to the connector board.
  7. Behringer BCD3000 Disassembly: adım 7, 3 resimden 1. Behringer BCD3000 Disassembly: adım 7, 3 resimden 2. Behringer BCD3000 Disassembly: adım 7, 3 resimden 3.
    • Slide the lower section to the front.
    • Now you can lift it and take it aside.
  8. Behringer BCD3000 Disassembly: adım 8, 3 resimden 1. Behringer BCD3000 Disassembly: adım 8, 3 resimden 2. Behringer BCD3000 Disassembly: adım 8, 3 resimden 3.
    • Disconnect the separate boards.
    • Now you can take the modules out by unscrewing them from the case.
  9. Behringer BCD3000 Disassembly: adım 9, 2 resimden 1. Behringer BCD3000 Disassembly: adım 9, 2 resimden 2.
    • The jog wheels on the front panel can be taken off by using a spudger and levering them out.
  10. Behringer BCD3000 Disassembly: adım 10, 2 resimden 1. Behringer BCD3000 Disassembly: adım 10, 2 resimden 2.
    • The knobs can easy be removed just by pulling.
  11. Behringer BCD3000 Disassembly: adım 11, 3 resimden 1. Behringer BCD3000 Disassembly: adım 11, 3 resimden 2. Behringer BCD3000 Disassembly: adım 11, 3 resimden 3.
    • Same goes for the knobs on the top section of the front panel.
Sonuç
5 farklı kişi bu kılavuzu tamamladı.
Tobias Isakeit
124.347 İtibar
189 adet Kılavuz yazıldı
Ekip
2Kılavuz Yorumları
Pensaba que serviría para la BCD2000… pero es algo distinta.
Antonio - Yanıt
great stuff, with better quality pictures would be better
csipapicsa - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 10
Son 30 gün: 67
Her zaman: 2,730
