Ana içeriğe geç
Giriş
Replace the battery in your Beiens Cartoon RC Race Car.
Parçalar
Hiçbir parça belirtilmedi.
  1. On the bottom of the car, unscrew the 6.2 mm screw that houses the batteries using a Philips 00 precision screwdriver.
    • On the bottom of the car, unscrew the 6.2 mm screw that houses the batteries using a Philips 00 precision screwdriver.
  2. Dizüstü Bilgisayar Bataryaları
    An easy fix for a big power boost.
    Hemen Alışveriş Yapın
  3. Pull up the tab to reveal the battery compartment.
    • Pull up the tab to reveal the battery compartment.
  4. Insert AA batteries into the 3 spaces with the flat end of the battery facing the metal spring.
    • Insert AA batteries into the 3 spaces with the flat end of the battery facing the metal spring.
    • Be sure to insert the batteries with the positive and negative ends facing the right direction. The flat negative end of the battery should be in contact with the spring in the remote control car.
Sonuç
Amber Ashley
329 İtibar
4 adet Kılavuz yazıldı
Takım
USF Tampa, Team 1-6, Leahy Fall 2015 USF Tampa, Team 1-6, Leahy Fall 2015 üyesi
USFT-LEAHY-F15S1G6
3 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 Gün: 1
Son 30 Gün: 5
Her zaman: 239
