Ana içeriğe geç
Parçalar
Hiçbir parça belirtilmedi.
  1. Hold the remote control with the backside facing you and, using the Phillips #00 screwdriver, unscrew the six 6.5 mm screws on the back of the controller that hold it together.
    • Hold the remote control with the backside facing you and, using the Phillips #00 screwdriver, unscrew the six 6.5 mm screws on the back of the controller that hold it together.
  2. After unscrewing the six screws,  pull the the device apart to reveal where the antenna meets the long white wire.
    • After unscrewing the six screws, pull the the device apart to reveal where the antenna meets the long white wire.
  3. Remove the 4.5 mm screw  on the remote that holds the antenna in place to set it loose.
    • Remove the 4.5 mm screw on the remote that holds the antenna in place to set it loose.
  4. Replace the old antenna with a new one. Attach the new antenna to the white wire and screw it in place.
    • Replace the old antenna with a new one. Attach the new antenna to the white wire and screw it in place.
Sonuç
Amber Ashley
329 İtibar
4 adet Kılavuz yazıldı
Takım
USF Tampa, Team 1-6, Leahy Fall 2015 USF Tampa, Team 1-6, Leahy Fall 2015 üyesi
USFT-LEAHY-F15S1G6
3 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 Gün: 1
Son 30 Gün: 1
Her zaman: 202
