Ana içeriğe geç
Belkin F5L114 Battery Replacement
Neye ihtiyacın var
  1. Belkin F5L114 Battery Replacement, Battery: adım 1, 3 resimden 1. Belkin F5L114 Battery Replacement, Battery: adım 1, 3 resimden 2. Belkin F5L114 Battery Replacement, Battery: adım 1, 3 resimden 3.
    • Switch the power button that is located at the bottom left of the keyboard to Off.
  2. Belkin F5L114 Battery Replacement: adım 2, 2 resimden 1. Belkin F5L114 Battery Replacement: adım 2, 2 resimden 2.
    • Flip the keyboard over.
  3. Belkin F5L114 Battery Replacement: adım 3, 3 resimden 1. Belkin F5L114 Battery Replacement: adım 3, 3 resimden 2. Belkin F5L114 Battery Replacement: adım 3, 3 resimden 3.
    • Pull back gently on the left side of the bottom-left rubber foot enough to expose the small screw.
  4. Belkin F5L114 Battery Replacement: adım 4, 1 resimden 1.
    • Use a Phillips #0 screwdriver to unscrew the screw.
    • The screw may not come fully out of the device.
  5. Belkin F5L114 Battery Replacement: adım 5, 1 resimden 1.
    • Pull back gently on the bottom left corner of the middle rubber foot enough to expose the small screw.
  6. Belkin F5L114 Battery Replacement: adım 6, 1 resimden 1.
  7. Belkin F5L114 Battery Replacement: adım 7, 2 resimden 1. Belkin F5L114 Battery Replacement: adım 7, 2 resimden 2.
    • Pull back gently on the right side of the bottom-right rubber enough to expose the small screw.
  8. Belkin F5L114 Battery Replacement: adım 8, 1 resimden 1.
  9. Belkin F5L114 Battery Replacement: adım 9, 2 resimden 1. Belkin F5L114 Battery Replacement: adım 9, 2 resimden 2.
    • Insert the spudger into the space next to the right screw area.
    • Gently pry open the battery case.
  10. Belkin F5L114 Battery Replacement: adım 10, 3 resimden 1. Belkin F5L114 Battery Replacement: adım 10, 3 resimden 2. Belkin F5L114 Battery Replacement: adım 10, 3 resimden 3.
    • Gently pry the battery cover off.
  11. Belkin F5L114 Battery Replacement: adım 11, 2 resimden 1. Belkin F5L114 Battery Replacement: adım 11, 2 resimden 2.
    • Remove the battery cover.
    • Locate the battery.
  12. Belkin F5L114 Battery Replacement: adım 12, 2 resimden 1. Belkin F5L114 Battery Replacement: adım 12, 2 resimden 2.
    • Lift the battery up using the spudger.
    • The battery is taped down.
  13. Belkin F5L114 Battery Replacement: adım 13, 3 resimden 1. Belkin F5L114 Battery Replacement: adım 13, 3 resimden 2. Belkin F5L114 Battery Replacement: adım 13, 3 resimden 3.
    Bu adımda kullanılan alet:
    • Gently unplug the battery from the motherboard using the tweezers.
    • Remove the battery.
Sonuç
Bir başkası bu kılavuzu tamamladı.
4Kılavuz Yorumları
Hi, I would like buy another battery for my keyboard. May you help me please?
Rundy Henry - Yanıt
I’m not 100% sure but I think you can find them on Amazon.
Michelle Bianco -
Where can I buy a new battery?
Kingstonite - Yanıt
Michelle Bianco -
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 7
Son 30 gün: 56
Her zaman: 1,257
