Ana içeriğe geç
Belkin NetCam HD Lens Piece Replacement
Neye ihtiyacın var
    1. Belkin NetCam HD Lens Piece  Replacement, Case: adım 1, 1 resimden 1.
      • Use a wrench to loosen up the stand from the back in order to hold the NetCam more comfortably.
      FixBot'a Sor
      Yorum Ekle
    2. Belkin NetCam HD Lens Piece  Replacement: adım 2, 1 resimden 1.
      • Work a plastic opening tool into the seam and pry the face plate away from the back panel.
      FixBot'a Sor
      Yorum Ekle
    3. Belkin NetCam HD Lens Piece  Replacement: adım 3, 2 resimden 1. Belkin NetCam HD Lens Piece  Replacement: adım 3, 2 resimden 2.
      • Use pressure to separate the covers.
      • When pulling the device apart, separate from the bottom up in order to avoid pulling the wiring at the top apart.
      FixBot'a Sor
      Yorum Ekle
    1. Belkin NetCam HD Lens Piece  Replacement, Front Casing: adım 4, 1 resimden 1.
      • Carefully use your fingers to gently pull out the white attachment from the tan colored part.
      FixBot'a Sor
      Yorum Ekle
    1. Belkin NetCam HD Lens Piece  Replacement, Speaker: adım 5, 2 resimden 1. Belkin NetCam HD Lens Piece  Replacement, Speaker: adım 5, 2 resimden 2.
      • Use a Phillips #0 screwdriver to take out the two 1.2 mm screws on the board.
      FixBot'a Sor
      Yorum Ekle
    2. Belkin NetCam HD Lens Piece  Replacement: adım 6, 3 resimden 1. Belkin NetCam HD Lens Piece  Replacement: adım 6, 3 resimden 2. Belkin NetCam HD Lens Piece  Replacement: adım 6, 3 resimden 3.
      • With your fingers, pull the circuit board out of the back casing.
      • When pulling the board up be sure to do so carefully so you do not break the cord which is attached on the back side.
      FixBot'a Sor
      Yorum Ekle
    3. Belkin NetCam HD Lens Piece  Replacement: adım 7, 2 resimden 1. Belkin NetCam HD Lens Piece  Replacement: adım 7, 2 resimden 2.
      • Gently pull the speaker out of the holder from the back of the cover.
      FixBot'a Sor
      Yorum Ekle
    4. Belkin NetCam HD Lens Piece  Replacement: adım 8, 1 resimden 1.
      • The speaker wires are attached with the board. It can be unattached gently by pulling out the white attachment from the port.
      FixBot'a Sor
      Yorum Ekle
    1. Belkin NetCam HD Lens Piece  Replacement, Lens Piece: adım 9, 2 resimden 1. Belkin NetCam HD Lens Piece  Replacement, Lens Piece: adım 9, 2 resimden 2.
      • Flip the circuit board to the back side.
      • Fold down the tape with your finger.
      • With the Phillips #0 screwdriver, unscrew the two 1.2 mm screws.
      FixBot'a Sor
      Yorum Ekle
    2. Belkin NetCam HD Lens Piece  Replacement: adım 10, 2 resimden 1. Belkin NetCam HD Lens Piece  Replacement: adım 10, 2 resimden 2.
      • Flip the circuit board back to the other side.
      • Unscrew the screw with a Phillips #0 screw driver.
      FixBot'a Sor
      Yorum Ekle
    3. Belkin NetCam HD Lens Piece  Replacement: adım 11, 1 resimden 1.
      • Slide the attached piece from the lens holder device.
      FixBot'a Sor
      Yorum Ekle
    4. Belkin NetCam HD Lens Piece  Replacement: adım 12, 2 resimden 1. Belkin NetCam HD Lens Piece  Replacement: adım 12, 2 resimden 2.
      Bu adımda kullanılan alet:
      • Use the tweezers to pull the white attachment out from the port a little.
      • Then, take your fingers and gently pull the white attachment out from the tan port.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Destinie DiazVerdejo
805 İtibar
7 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 3-5, Sullivan Fall 2016 USF Tampa, Team 3-5, Sullivan Fall 2016 üyesi
USFT-SULLIVAN-F16S3G5
4 Üyeler
21 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 5
Son 30 gün: 26
Her zaman: 1,406
