Ana içeriğe geç
Belkin NetCam HD Switch Cover Replacement
Neye ihtiyacın var
  1. Belkin NetCam HD Switch Cover Replacement, Case: adım 1, 1 resimden 1.
    • Use a wrench to loosen up the stand from the back in order to hold the NetCam more comfortably.
  2. Belkin NetCam HD Switch Cover Replacement: adım 2, 1 resimden 1.
    • Work a plastic opening tool into the seam and pry the face plate away from the back panel.
  3. Belkin NetCam HD Switch Cover Replacement: adım 3, 2 resimden 1. Belkin NetCam HD Switch Cover Replacement: adım 3, 2 resimden 2.
    • Use pressure to separate the covers.
    • When pulling the device apart, separate from the bottom up in order to avoid pulling the wiring at the top apart.
  4. Belkin NetCam HD Switch Cover Replacement, Front Casing: adım 4, 1 resimden 1.
    • Carefully use your fingers to gently pull out the white attachment from the tan colored part.
  5. Belkin NetCam HD Switch Cover Replacement, Speaker: adım 5, 2 resimden 1. Belkin NetCam HD Switch Cover Replacement, Speaker: adım 5, 2 resimden 2.
    • Use a Phillips #0 screwdriver to take out the two 1.2 mm screws on the board.
  6. Belkin NetCam HD Switch Cover Replacement: adım 6, 3 resimden 1. Belkin NetCam HD Switch Cover Replacement: adım 6, 3 resimden 2. Belkin NetCam HD Switch Cover Replacement: adım 6, 3 resimden 3.
    • With your fingers, pull the circuit board out of the back casing.
    • When pulling the board up be sure to do so carefully so you do not break the cord which is attached on the back side.
  7. Belkin NetCam HD Switch Cover Replacement: adım 7, 2 resimden 1. Belkin NetCam HD Switch Cover Replacement: adım 7, 2 resimden 2.
    • Gently pull the speaker out of the holder from the back of the cover.
  8. Belkin NetCam HD Switch Cover Replacement: adım 8, 1 resimden 1.
    • The speaker wires are attached with the board. It can be unattached gently by pulling out the white attachment from the port.
  9. Belkin NetCam HD Switch Cover Replacement, Switch Cover: adım 9, 2 resimden 1. Belkin NetCam HD Switch Cover Replacement, Switch Cover: adım 9, 2 resimden 2.
    • On the back of the board pull the switch slowly upward to take it off.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Destinie DiazVerdejo
805 İtibar
7 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 3-5, Sullivan Fall 2016 USF Tampa, Team 3-5, Sullivan Fall 2016 üyesi
USFT-SULLIVAN-F16S3G5
4 Üyeler
14 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 2
Her zaman: 257
