Ana içeriğe geç
Bell and Howell DNV16HDZ Hand Strap Replacement
Neye ihtiyacın var
  1. Bell and Howell DNV16HDZ Hand Strap Replacement, Lens Assembly: adım 1, 2 resimden 1. Bell and Howell DNV16HDZ Hand Strap Replacement, Lens Assembly: adım 1, 2 resimden 2.
    • Remove the five 30mm Phillips #0 screws on the bottom of the camera.
  2. Bell and Howell DNV16HDZ Hand Strap Replacement: adım 2, 1 resimden 1.
    • Use a plastic opening tool to disconnect the internal hinges that snaps the camera into place.
    • Using a plastic opening tool is important since a metal one will scratch or damage the thin plastic hinges that hold the camera together.
  3. Bell and Howell DNV16HDZ Hand Strap Replacement: adım 3, 1 resimden 1.
    • It will still be connected by a plastic film. This can also be disconnected by pulling up the white part where it connects to the light circuit board.
  4. Bell and Howell DNV16HDZ Hand Strap Replacement, Hand Strap: adım 4, 2 resimden 1. Bell and Howell DNV16HDZ Hand Strap Replacement, Hand Strap: adım 4, 2 resimden 2.
    • Pull the side with the hand strap upwards to disconnect it from the camcorder.
    • Unscrew the four 40 mm Phillips #0 screws.
    • Add the new hand strap now.
Sonuç
Jerry Hadjah
525 İtibar
5 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 8-4, Botvin Spring 2016 UMass Dartmouth, Team 8-4, Botvin Spring 2016 üyesi
UMASSD-BOTVIN-S16S8G4
3 Üyeler
12 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 16
Her zaman: 202
