Ana içeriğe geç
Bell and Howell DNV16HDZ LED Replacement
Neye ihtiyacın var
  1. Bell and Howell DNV16HDZ LED Replacement, Lens Assembly: adım 1, 2 resimden 1. Bell and Howell DNV16HDZ LED Replacement, Lens Assembly: adım 1, 2 resimden 2.
    • Remove the five 30mm Phillips #0 screws on the bottom of the camera.
  2. Bell and Howell DNV16HDZ LED Replacement: adım 2, 1 resimden 1.
    • Use a plastic opening tool to disconnect the internal hinges that snaps the camera into place.
    • Using a plastic opening tool is important since a metal one will scratch or damage the thin plastic hinges that hold the camera together.
  3. Bell and Howell DNV16HDZ LED Replacement: adım 3, 1 resimden 1.
    • It will still be connected by a plastic film. This can also be disconnected by pulling up the white part where it connects to the light circuit board.
  4. Bell and Howell DNV16HDZ LED Replacement, LED: adım 4, 1 resimden 1.
    • Take out the two 20 mm Phillips #0 screws that attach it to the shutter.
  5. Bell and Howell DNV16HDZ LED Replacement: adım 5, 3 resimden 1. Bell and Howell DNV16HDZ LED Replacement: adım 5, 3 resimden 2. Bell and Howell DNV16HDZ LED Replacement: adım 5, 3 resimden 3.
    • The two 30 mm Phillips #0 screws left can be removed to gain access to the circuit board along with the LED.
    • From here we can pop out the LED using the wedge or your fingers if you can manage it.
Sonuç
Donald Desrosier
101 İtibar
1 Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 8-4, Botvin Spring 2016 UMass Dartmouth, Team 8-4, Botvin Spring 2016 üyesi
UMASSD-BOTVIN-S16S8G4
3 Üyeler
12 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 9
Her zaman: 296
