Ana içeriğe geç
Bella 4-Slice Toaster Oven Outer Shell Replacement
Neye ihtiyacın var
  1. Bella 4-Slice Toaster Oven Outer Shell Replacement, Outer Shell: adım 1, 1 resimden 1.
    • Remove five 11.6 mm Phillips #2 screws from the rear of the device.
  2. Bella 4-Slice Toaster Oven Outer Shell Replacement: adım 2, 1 resimden 1.
    • Open the front glass door of the toaster oven.
  3. Bella 4-Slice Toaster Oven Outer Shell Replacement: adım 3, 1 resimden 1.
    • Locate retaining screw on the upper-middle portion of the door frame.
  4. Bella 4-Slice Toaster Oven Outer Shell Replacement: adım 4, 1 resimden 1.
    • Remove one 21.9 mm Phillips #2 retaining screw from upper-middle portion of door frame.
  5. Bella 4-Slice Toaster Oven Outer Shell Replacement: adım 5, 1 resimden 1.
    • Flip toaster onto back panel with feet facing forward.
  6. Bella 4-Slice Toaster Oven Outer Shell Replacement: adım 6, 1 resimden 1.
    • Use spudger to pry the grey rubber inserts from the black plastic feet.
  7. Bella 4-Slice Toaster Oven Outer Shell Replacement: adım 7, 1 resimden 1.
    • Remove four 13.7mm Phillips #2 screws from black plastic feet to separate the cover from the device.
  8. Bella 4-Slice Toaster Oven Outer Shell Replacement: adım 8, 1 resimden 1.
    • Lift the black outer cover off of the toaster
Sonuç
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 12
Her zaman: 437
