Ana içeriğe geç
Bella 4-Slice Toaster Oven Timer Replacement
Neye ihtiyacın var
  1. Bella 4-Slice Toaster Oven Timer Replacement, Outer Shell: adım 1, 1 resimden 1.
    • Remove five 11.6 mm Phillips #2 screws from the rear of the device.
  2. Bella 4-Slice Toaster Oven Timer Replacement: adım 2, 1 resimden 1.
    • Open the front glass door of the toaster oven.
  3. Bella 4-Slice Toaster Oven Timer Replacement: adım 3, 1 resimden 1.
    • Locate retaining screw on the upper-middle portion of the door frame.
  4. Bella 4-Slice Toaster Oven Timer Replacement: adım 4, 1 resimden 1.
    • Remove one 21.9 mm Phillips #2 retaining screw from upper-middle portion of door frame.
  5. Bella 4-Slice Toaster Oven Timer Replacement: adım 5, 1 resimden 1.
    • Flip toaster onto back panel with feet facing forward.
  6. Bella 4-Slice Toaster Oven Timer Replacement: adım 6, 1 resimden 1.
    • Use spudger to pry the grey rubber inserts from the black plastic feet.
  7. Bella 4-Slice Toaster Oven Timer Replacement: adım 7, 1 resimden 1.
    • Remove four 13.7mm Phillips #2 screws from black plastic feet to separate the cover from the device.
  8. Bella 4-Slice Toaster Oven Timer Replacement: adım 8, 1 resimden 1.
    • Lift the black outer cover off of the toaster
  9. Bella 4-Slice Toaster Oven Timer Replacement, Timer: adım 9, 1 resimden 1.
    • Using a plastic spudger, gently pry the black plastic timing dial away from the face of the toaster.
  10. Bella 4-Slice Toaster Oven Timer Replacement: adım 10, 2 resimden 1. Bella 4-Slice Toaster Oven Timer Replacement: adım 10, 2 resimden 2.
    • Remove two 5.91 mm #2 Phillips screws which secure the timer to the toaster.
  11. Bella 4-Slice Toaster Oven Timer Replacement: adım 11, 3 resimden 1. Bella 4-Slice Toaster Oven Timer Replacement: adım 11, 3 resimden 2. Bella 4-Slice Toaster Oven Timer Replacement: adım 11, 3 resimden 3.
    • Inside the device, unplug the red and black wires from the top of the timer.
  12. Bella 4-Slice Toaster Oven Timer Replacement: adım 12, 1 resimden 1.
    • Remove timer from device interior.
Sonuç
Bir başkası bu kılavuzu tamamladı.
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 14
Her zaman: 715
