Ana içeriğe geç
Bella Cucina Mini Cupcake Maker 13465 Disassembly
Neye ihtiyacın var
  1. Bella Cucina Mini Cupcake Maker 13465 Disassembly, Bella Cucina Mini Cupcake Maker 13465 Disassembly: adım 1, 3 resimden 1. Bella Cucina Mini Cupcake Maker 13465 Disassembly, Bella Cucina Mini Cupcake Maker 13465 Disassembly: adım 1, 3 resimden 2. Bella Cucina Mini Cupcake Maker 13465 Disassembly, Bella Cucina Mini Cupcake Maker 13465 Disassembly: adım 1, 3 resimden 3.
    • Open up the device.
    • Remove the four 11 mm screws that attach the alloy steel body to the top plastic cover using the Phillips #1 screwdriver.
    • Place the screws in the IFixit magnetic project mat.
    • Remove the plastic cover.
  2. Bella Cucina Mini Cupcake Maker 13465 Disassembly: adım 2, 3 resimden 1. Bella Cucina Mini Cupcake Maker 13465 Disassembly: adım 2, 3 resimden 2. Bella Cucina Mini Cupcake Maker 13465 Disassembly: adım 2, 3 resimden 3.
    • Remove the LEDs from the springs that are located towards the front between the heating element and the cover.
    • The heating element has a resistance of 39.4 ohm at room temperature.
    • Remove the 6 mm screws that attach the springs to the main alloy body using a Phillips #2 screwdriver.
  3. Bella Cucina Mini Cupcake Maker 13465 Disassembly: adım 3, 3 resimden 1. Bella Cucina Mini Cupcake Maker 13465 Disassembly: adım 3, 3 resimden 2. Bella Cucina Mini Cupcake Maker 13465 Disassembly: adım 3, 3 resimden 3.
    • Flip the cupcake maker so that the bottom side faces upwards.
    • Remove the two adjacent 12 mm screws using a Phillips #2 screwdriver.
    • Remove the remaining 11 mm screw using a Phillips #2 screwdriver.
    • Gently remove the case to reveal the space where the main power cable splits into two wires.
  4. Bella Cucina Mini Cupcake Maker 13465 Disassembly: adım 4, 3 resimden 1. Bella Cucina Mini Cupcake Maker 13465 Disassembly: adım 4, 3 resimden 2. Bella Cucina Mini Cupcake Maker 13465 Disassembly: adım 4, 3 resimden 3.
    • Remove the 13 mm screw that is located in the middle of the back cover using the Phillips #2 screwdriver.
    • Gently pull out the back cover to reveal the space containing the wires, heat fuse, and the insulating cover.
  5. Bella Cucina Mini Cupcake Maker 13465 Disassembly: adım 5, 3 resimden 1. Bella Cucina Mini Cupcake Maker 13465 Disassembly: adım 5, 3 resimden 2. Bella Cucina Mini Cupcake Maker 13465 Disassembly: adım 5, 3 resimden 3.
    • Remove the 6 mm screw using a Phillips #2 screw driver that attaches the cable clamp and the insulating cover to the main body.
    • Pull out the yellow wire from the clamp
    • Remove the insulating cover.
    • The bottom cupcake heating element is located below the insulating cover. It has a resistance of 39.4 ohm at room temperature.
  6. Bella Cucina Mini Cupcake Maker 13465 Disassembly: adım 6, 3 resimden 1. Bella Cucina Mini Cupcake Maker 13465 Disassembly: adım 6, 3 resimden 2. Bella Cucina Mini Cupcake Maker 13465 Disassembly: adım 6, 3 resimden 3.
    • Remove the two screws that attach the heat switch clamp to the body using the Phillips #2 screwdriver.
    • Pull out the heat fuse.
    • Be careful when removing the heat switch so that it does not break.
    • The heat switch opens when the temperature is above 165 degree Celsius.
  7. Bella Cucina Mini Cupcake Maker 13465 Disassembly: adım 7, 1 resimden 1.
    • The device does not have any switch. It turns on automatically when the power cable is connected to a 120 volt AC supply. It has a power rating of 710 Watts.
    • The current passes through the heat switch before going through the two heating elements.
    • Both the green and orange LED light up when the device is working. However, the heat switch opens if the temperature becomes very high (exceeds 165 degree Celsius).
    • Therefore, current stops flowing through the heating elements to prevent any accident.
    • When the fuse melts, only the orange LED will remain on , indicating that the heating elements have been shut off.
Sonuç
Bir başkası bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 7
Her zaman: 137
