Ana içeriğe geç
Bella TXG-FS075A Heating Element Replacement
Neye ihtiyacın var
    1. Bella TXG-FS075A Heating Element Replacement, Heating Element: adım 1, 3 resimden 1. Bella TXG-FS075A Heating Element Replacement, Heating Element: adım 1, 3 resimden 2. Bella TXG-FS075A Heating Element Replacement, Heating Element: adım 1, 3 resimden 3.
      • Use a spudger to pry off the metal top of the air fryer.
      FixBot'a Sor
      Yorum Ekle
    2. Bella TXG-FS075A Heating Element Replacement: adım 2, 2 resimden 1. Bella TXG-FS075A Heating Element Replacement: adım 2, 2 resimden 2.
      • Use an iFixit opening tool to pry off the plastic frame.
      FixBot'a Sor
      Yorum Ekle
    3. Bella TXG-FS075A Heating Element Replacement: adım 3, 3 resimden 1. Bella TXG-FS075A Heating Element Replacement: adım 3, 3 resimden 2. Bella TXG-FS075A Heating Element Replacement: adım 3, 3 resimden 3.
      • Remove the four 13 mm screws from the second plastic frame using a Phillips #2 screwdriver.
      • Pry off the black plastic frame.
      FixBot'a Sor
      Yorum Ekle
    4. Bella TXG-FS075A Heating Element Replacement: adım 4, 1 resimden 1.
      • Remove the two 13 mm screws using a Phillips #2 screwdriver.
      FixBot'a Sor
      Yorum Ekle
    5. Bella TXG-FS075A Heating Element Replacement: adım 5, 3 resimden 1. Bella TXG-FS075A Heating Element Replacement: adım 5, 3 resimden 2. Bella TXG-FS075A Heating Element Replacement: adım 5, 3 resimden 3.
      • Using a spudger, pry off the outer frame.
      • Pull up on the outer frame, exposing the inner wall of the fryer.
      FixBot'a Sor
      Yorum Ekle
    6. Bella TXG-FS075A Heating Element Replacement: adım 6, 2 resimden 1. Bella TXG-FS075A Heating Element Replacement: adım 6, 2 resimden 2.
      • Remove the 13 mm screw connecting to the heating element's bracket using a Phillips #2 screwdriver.
      FixBot'a Sor
      Yorum Ekle
    7. Bella TXG-FS075A Heating Element Replacement: adım 7, 2 resimden 1. Bella TXG-FS075A Heating Element Replacement: adım 7, 2 resimden 2.
      • Pull out the heating element.
      FixBot'a Sor
      Yorum Ekle
Sonuç
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 10
Son 30 gün: 42
Her zaman: 1,088
