Ana içeriğe geç
Bella TXG-FS075A Motherboard Replacement
Neye ihtiyacın var
  1. Bella TXG-FS075A Motherboard Replacement, Motherboard: adım 1, 3 resimden 1. Bella TXG-FS075A Motherboard Replacement, Motherboard: adım 1, 3 resimden 2. Bella TXG-FS075A Motherboard Replacement, Motherboard: adım 1, 3 resimden 3.
    • Use a spudger to pry off the metal top of the air fryer.
  2. Bella TXG-FS075A Motherboard Replacement: adım 2, 2 resimden 1. Bella TXG-FS075A Motherboard Replacement: adım 2, 2 resimden 2.
    • Use an iFixit opening tool to pry off the plastic frame.
  3. Bella TXG-FS075A Motherboard Replacement: adım 3, 3 resimden 1. Bella TXG-FS075A Motherboard Replacement: adım 3, 3 resimden 2. Bella TXG-FS075A Motherboard Replacement: adım 3, 3 resimden 3.
    • Remove the four 13 mm screws from the second plastic frame using a Phillips #2 screwdriver.
    • Pry off the black plastic frame.
  4. Bella TXG-FS075A Motherboard Replacement: adım 4, 2 resimden 1. Bella TXG-FS075A Motherboard Replacement: adım 4, 2 resimden 2.
    • Remove the two 13 mm screws from the base of the motherboard using a Phillips #2 screwdriver.
  5. Bella TXG-FS075A Motherboard Replacement: adım 5, 1 resimden 1.
    • Pull up and remove the motherboard.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 9
Her zaman: 54
