Ana içeriğe geç
BenQ HT1075 Projector Blower Fan Replacement
Neye ihtiyacın var
  1. BenQ HT1075 Projector Blower Fan Replacement, Lamp: adım 1, 1 resimden 1.
    • Loosen the 2.5 mm Phillips #1 screw that holds the top assembly in place using a Philips #1 (PH1) screwdriver. This will enable you to lift and slide off the top cover.
    • Fully remove the top cover in order to get to the lamp housing.
  2. BenQ HT1075 Projector Blower Fan Replacement: adım 2, 1 resimden 1.
    • Carefully peel off the adhesive film covering the lamp housing.
  3. BenQ HT1075 Projector Blower Fan Replacement: adım 3, 1 resimden 1.
    • Using a Phillips #1 (PH1) screwdriver, loosen and remove the single 2.5 mm Phillips #1 screw that secures the lamp housing to the projector.
  4. BenQ HT1075 Projector Blower Fan Replacement: adım 4, 1 resimden 1.
    • Remove the lamp from the projector by pulling on the lamp handle.
    • Apply more force on the side opposite of the newly removed screw as you pull the lamp out.
  5. BenQ HT1075 Projector Blower Fan Replacement, Circuit Board: adım 5, 1 resimden 1.
    • Turn the projector over and remove the five 9.5 mm Phillips #1 screws that hold the back cover with a Phillips #1 (PH1) screwdriver.
  6. BenQ HT1075 Projector Blower Fan Replacement, Remove the 6th screw holding the top cover: adım 6, 1 resimden 1.
    • Flip the projector and remove the 6th and last crew.
  7. BenQ HT1075 Projector Blower Fan Replacement: adım 7, 1 resimden 1.
    • Using an opening tool, remove the top cover by first loosening its top cover.
  8. BenQ HT1075 Projector Blower Fan Replacement: adım 8, 2 resimden 1. BenQ HT1075 Projector Blower Fan Replacement: adım 8, 2 resimden 2.
    • Unplug the wire that connects the front cover to the circuit board.
    • Now use the opening tool to pry the front cover from the platform.
    • Gently pull the top cover from the rest of the frame.
  9. BenQ HT1075 Projector Blower Fan Replacement: adım 9, 2 resimden 1. BenQ HT1075 Projector Blower Fan Replacement: adım 9, 2 resimden 2.
    • To prevent potential for electrical damage, disconnect any wires connected to the circuit board.
    • Using the opening tool, loosen the sides of the platform. Then gently pull them off from the projector components.
  10. BenQ HT1075 Projector Blower Fan Replacement: adım 10, 3 resimden 1. BenQ HT1075 Projector Blower Fan Replacement: adım 10, 3 resimden 2. BenQ HT1075 Projector Blower Fan Replacement: adım 10, 3 resimden 3.
    • Remove these four 8.5 mm Phillips #1 screws using a Phillips #1 (PH1) screwdriver.
    • Afterwards, use a 5mm nut driver to remove the four remaining screws.
    • Use the opening tool to loosen the back cover then pull it off.
  11. BenQ HT1075 Projector Blower Fan Replacement: adım 11, 1 resimden 1.
    • With a Phillips #1 (PH1) screwdriver, remove the four 6.3 mm Phillips screws that hold the metal casing on top of the circuit board.
    • Remove the metal casing.
  12. BenQ HT1075 Projector Blower Fan Replacement: adım 12, 2 resimden 1. BenQ HT1075 Projector Blower Fan Replacement: adım 12, 2 resimden 2.
    • Using the Phillips #1 (PH1) screwdriver, remove the three 6.3 mm Phillips #1 screws holding down the circuit board.
    • Carefully pull the circuit board from the frame, adding force to the area where the pushbuttons are located.
  13. BenQ HT1075 Projector Blower Fan Replacement, Blower Fan: adım 13, 2 resimden 1. BenQ HT1075 Projector Blower Fan Replacement, Blower Fan: adım 13, 2 resimden 2.
    • Unscrew the Philips #1 (PH1) screw securing the green wire located at the bottom left of the metal casing.
    • Remove a second Philips #1 (PH1) screw that holds down the top of the metal casing located near the back of the projector’s lens.
  14. BenQ HT1075 Projector Blower Fan Replacement: adım 14, 1 resimden 1.
    • Remove three Philips #2 (PH2) screws that attach the metal casing to the platform.
    • Remove the metal casing by pulling it straight up.
  15. BenQ HT1075 Projector Blower Fan Replacement: adım 15, 1 resimden 1.
    • Remove the two Philips #2 (PH2) screws that hold down the black blower fan, located at top center of the circuit board.
  16. BenQ HT1075 Projector Blower Fan Replacement: adım 16, 1 resimden 1.
    • Remove the three Philips #1 (PH1) screws that attach the blower fan to the metal cover.
    • Gently remove the blower fan by pulling it directly upwards from the base.
Sonuç
7 farklı kişi bu kılavuzu tamamladı.
Gabriela Remulla
912 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S6-G1, Banghart Fall 2017 Cal Poly, Team S6-G1, Banghart Fall 2017 üyesi
CPSU-BANGHART-F17S6G1
5 Üyeler
3 Yorum
I did the repair to clear out some dust and glass from a blown lamp. After putting it back together, I get lights most likely from no power at all. Do you think the next step would to be take back apart and make sure everything is connected correctly? I can be reached at jaspercloren@gmail.com or I will check back on here.
Thank you for all your write ups, they are very nice. I may suggest to get a closer view of the screws/bolts in case someone misplaces one.
Jasper Loren - Yanıt
where can we buy the replacement fan? Is there a part number for finding this part?
Rekhender Dhawan - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 6
Son 30 gün: 26
Her zaman: 9,643
