Ana içeriğe geç
BenQ HT1075 Projector Bulb Replacement
Neye ihtiyacın var
  1. BenQ HT1075 Projector Bulb Replacement, Lamp: adım 1, 1 resimden 1.
    • Loosen the 2.5 mm Phillips #1 screw that holds the top assembly in place using a Philips #1 (PH1) screwdriver. This will enable you to lift and slide off the top cover.
    • Fully remove the top cover in order to get to the lamp housing.
  2. BenQ HT1075 Projector Bulb Replacement: adım 2, 1 resimden 1.
    • Carefully peel off the adhesive film covering the lamp housing.
  3. BenQ HT1075 Projector Bulb Replacement: adım 3, 1 resimden 1.
    • Using a Phillips #1 (PH1) screwdriver, loosen and remove the single 2.5 mm Phillips #1 screw that secures the lamp housing to the projector.
  4. BenQ HT1075 Projector Bulb Replacement: adım 4, 1 resimden 1.
    • Remove the lamp from the projector by pulling on the lamp handle.
    • Apply more force on the side opposite of the newly removed screw as you pull the lamp out.
  5. BenQ HT1075 Projector Bulb Replacement, Bulb: adım 5, 1 resimden 1.
    • Using a Philips #0 (PH0) screwdriver, remove the two screws holding the metal case of the lamp housing.
  6. BenQ HT1075 Projector Bulb Replacement: adım 6, 1 resimden 1.
    • Using a 2.5mm Hex key, remove the top portion that contains the handle. This portion is also attached to the bulb housing.
  7. BenQ HT1075 Projector Bulb Replacement: adım 7, 1 resimden 1.
    • With a Philips #0 (PH0) screwdriver, remove the four screws that secure the bulb to the housing unit.
  8. BenQ HT1075 Projector Bulb Replacement: adım 8, 1 resimden 1.
    • Using a Philips#1 (PH1) screwdriver, remove the 2.5 mm Phillips #1 screw that secures the wires to the detach bulb.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Gabriela Remulla
912 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S6-G1, Banghart Fall 2017 Cal Poly, Team S6-G1, Banghart Fall 2017 üyesi
CPSU-BANGHART-F17S6G1
5 Üyeler
3 Yorum
Hey, Thanks for sharing the steps setting a Project Bulb Replacement.
SupplyExpert - Yanıt
we recently replaced Ht 1075 bulb after the main bulb broke. the projector runs for 10 min and them shuts off due to overheating. previously that was not the case. what could be the issue and how we can isolate and fix the issue..
Subcon App - Yanıt
From my experience try replacing the main blower fan located under the motherboard
Robert Koss -
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 21
Her zaman: 3,376
