Ana içeriğe geç
BenQ HT1075 Projector Lamp Replacement
Neye ihtiyacın var
  1. BenQ HT1075 Projector Lamp Replacement, Lamp: adım 1, 1 resimden 1.
    • Loosen the 2.5 mm Phillips #1 screw that holds the top assembly in place using a Philips #1 (PH1) screwdriver. This will enable you to lift and slide off the top cover.
    • Fully remove the top cover in order to get to the lamp housing.
    FixBot'a Sor
    Yorum Ekle
  2. BenQ HT1075 Projector Lamp Replacement: adım 2, 1 resimden 1.
    • Carefully peel off the adhesive film covering the lamp housing.
    FixBot'a Sor
    Yorum Ekle
  3. BenQ HT1075 Projector Lamp Replacement: adım 3, 1 resimden 1.
    • Using a Phillips #1 (PH1) screwdriver, loosen and remove the single 2.5 mm Phillips #1 screw that secures the lamp housing to the projector.
    FixBot'a Sor
    Yorum Ekle
  4. BenQ HT1075 Projector Lamp Replacement: adım 4, 1 resimden 1.
    • Remove the lamp from the projector by pulling on the lamp handle.
    • Apply more force on the side opposite of the newly removed screw as you pull the lamp out.
    FixBot'a Sor
    Yorum Ekle
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Gabriela Remulla
1.026 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S6-G1, Banghart Fall 2017 Cal Poly, Team S6-G1, Banghart Fall 2017 üyesi
CPSU-BANGHART-F17S6G1
5 Üyeler
9 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 8
Son 30 gün: 41
Her zaman: 2,183
