Giriş
How to disassemble your Benchmade Griptillian
Neye ihtiyacın var
Be sure to make note of what side the belt clip is on for reassembly.
Use the T6 bit to remove the four screws holding the handle in place.
Turn the knife over and remove the T8 screw that is going through the hinge.
Using the T6 bit, drive the hinge pin out of the other handle.
Using 600 grit sandpaper and a flat surface, rub both sides of the copper washers until there is new material showing.
3 farklı kişi bu kılavuzu tamamladı.
