Ana içeriğe geç
Benchmade Griptillian Disassembly
Neye ihtiyacın var
    1. Benchmade Griptillian Disassembly, Close the blade and turn the knife to the side that has the belt clip: adım 1, 1 resimden 1.
      • Be sure to make note of what side the belt clip is on for reassembly.
      FixBot'a Sor
      Yorum Ekle
    2. Benchmade Griptillian Disassembly, Remove screws: adım 2, 1 resimden 1.
      • Use a T6 bit to remove the two screws holding the belt clip.
      FixBot'a Sor
      Yorum Ekle
    3. Benchmade Griptillian Disassembly, Remove T6 Screws: adım 3, 1 resimden 1.
      • Use the T6 bit to remove the four screws holding the handle in place.
      FixBot'a Sor
      Yorum Ekle
    4. Benchmade Griptillian Disassembly, Turn the knife over: adım 4, 1 resimden 1.
      • Turn the knife over and remove one T6 screw.
      FixBot'a Sor
      Yorum Ekle
    5. Benchmade Griptillian Disassembly, Remove the T8 screw: adım 5, 1 resimden 1.
      • Turn the knife over and remove the T8 screw that is going through the hinge.
      FixBot'a Sor
      Yorum Ekle
    6. Benchmade Griptillian Disassembly, Remove the handle: adım 6, 1 resimden 1.
      • Once you've removed the screw, you can remove the handle.
      FixBot'a Sor
      Yorum Ekle
    7. Benchmade Griptillian Disassembly, Drive pin out of the other handle: adım 7, 1 resimden 1.
      • Using the T6 bit, drive the hinge pin out of the other handle.
      FixBot'a Sor
      Yorum Ekle
    8. Benchmade Griptillian Disassembly, Remove the other handle: adım 8, 1 resimden 1.
      • Once you've done this you can remove the other handle.
      FixBot'a Sor
      Yorum Ekle
    9. Benchmade Griptillian Disassembly, Slide the blade out of the frame: adım 9, 1 resimden 1.
      • Be sure to keep both brass washers. Sometimes they will stick to the frame or the blade.
      FixBot'a Sor
      Yorum Ekle
    10. Benchmade Griptillian Disassembly, Sand both sides of copper: adım 10, 1 resimden 1.
      • Using 600 grit sandpaper and a flat surface, rub both sides of the copper washers until there is new material showing.
      FixBot'a Sor
      Yorum Ekle
    11. Benchmade Griptillian Disassembly, Reverse process to re assemble: adım 11, 1 resimden 1.
      • Reverse process to re assemble.
      FixBot'a Sor
      Yorum Ekle
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Spin Modder
256 İtibar
1 Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 14
Son 30 gün: 70
Her zaman: 1,569
