Giriş
This guide shows you step-by-step how to fully disassemble the Best Budget Kettle. This way you can extensively clean the product and/or replace any torn down parts. This 2200 watt kettle has a capacity of 1.7 liter and is one of the cheapest of its kind.
Neye ihtiyacın var
Release the snap fits by sliding the metal spudger into each of the 4 slots and pressing the spudger to the side and pulling up on the cover.
This step is difficult to do with one person. We found it helpful to have one person holding the base and pulling up on the piece that was separating, while another person released the snapfits with the spudger.
Using the three-winged screwdriver, unscrew two three-winged screws from the top of the handle cover and two three-winged screws from the bottom of the handle cover and separate the handle cover from the kettle
Watch out not to ruin them by using the wrong tools (as in the second picture), because the screws are not that high quality.
Remove all parts from the electronic part. The copper parts and the springs can be removed by hand.
Push the part with the side where the prongs stick out against a hard surface to pop out the prongs. Then by pulling they can be removed.
The wires cannot be removed without breaking them.
