Ana içeriğe geç
Besta Super 5000 Back Cover Replacement
Neye ihtiyacın var
  1. Besta Super 5000 Back Cover Replacement, Battery: adım 1, 1 resimden 1.
    • Turn the device over so that the barcode is facing upwards.
  2. Besta Super 5000 Back Cover Replacement: adım 2, 2 resimden 1. Besta Super 5000 Back Cover Replacement: adım 2, 2 resimden 2.
    • Place your fingers on the battery cover arrow and pull the cover down and off the device.
  3. Besta Super 5000 Back Cover Replacement: adım 3, 1 resimden 1.
    • Pull upwards on the battery tab to remove the battery from the device.
  4. Besta Super 5000 Back Cover Replacement, Back Cover: adım 4, 1 resimden 1.
    • Remove the five screws around the edge of the device using a Phillips #0 screwdriver.
  5. Besta Super 5000 Back Cover Replacement: adım 5, 1 resimden 1.
    • Remove the two screws behind the battery using a Phillips #0 screwdriver.
  6. Besta Super 5000 Back Cover Replacement: adım 6, 2 resimden 1. Besta Super 5000 Back Cover Replacement: adım 6, 2 resimden 2.
    • Potential for device damage: All screws must be removed before you begin this step. Do not forcefully pry apart the device with screws still in it because you may damage it.
    • Gently pry off the backing using an opening tool.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Jessie
370 İtibar
3 adet Kılavuz yazıldı
Ekip
Ohio State, Team 1-5, Buehl Fall 2014 Ohio State, Team 1-5, Buehl Fall 2014 üyesi
OSU-BUEHL-F14S1G5
4 Üyeler
4 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 1
Her zaman: 279
