Ana içeriğe geç
Besta Super 5000 Motherboard Replacement
Neye ihtiyacın var
  1. Besta Super 5000 Motherboard Replacement, Battery: adım 1, 1 resimden 1.
    • Turn the device over so that the barcode is facing upwards.
  2. Besta Super 5000 Motherboard Replacement: adım 2, 2 resimden 1. Besta Super 5000 Motherboard Replacement: adım 2, 2 resimden 2.
    • Place your fingers on the battery cover arrow and pull the cover down and off the device.
  3. Besta Super 5000 Motherboard Replacement: adım 3, 1 resimden 1.
    • Pull upwards on the battery tab to remove the battery from the device.
  4. Besta Super 5000 Motherboard Replacement, Back Cover: adım 4, 1 resimden 1.
    • Remove the five screws around the edge of the device using a Phillips #0 screwdriver.
  5. Besta Super 5000 Motherboard Replacement: adım 5, 1 resimden 1.
    • Remove the two screws behind the battery using a Phillips #0 screwdriver.
  6. Besta Super 5000 Motherboard Replacement: adım 6, 2 resimden 1. Besta Super 5000 Motherboard Replacement: adım 6, 2 resimden 2.
    • Potential for device damage: All screws must be removed before you begin this step. Do not forcefully pry apart the device with screws still in it because you may damage it.
    • Gently pry off the backing using an opening tool.
  7. Besta Super 5000 Motherboard Replacement, Motherboard: adım 7, 1 resimden 1.
    • Remove the three silver screws from the black round battery using a Phillips #0 screwdriver.
  8. Besta Super 5000 Motherboard Replacement: adım 8, 1 resimden 1.
    • Remove the five small screws from the motherboard using a Phillips #0 screwdriver.
  9. Besta Super 5000 Motherboard Replacement: adım 9, 3 resimden 1. Besta Super 5000 Motherboard Replacement: adım 9, 3 resimden 2. Besta Super 5000 Motherboard Replacement: adım 9, 3 resimden 3.
    Bu adımda kullanılan alet:
    Satın Al
    • Using a pair of tweezers, pinch the center of the yellow ribbon located in the corner of the device.
    • Potential for device damage: Do not yank or remove the ribbon from the device.
    • Carefully pull the hidden piece of yellow ribbon out from underneath the motherboard.
  10. Besta Super 5000 Motherboard Replacement: adım 10, 2 resimden 1. Besta Super 5000 Motherboard Replacement: adım 10, 2 resimden 2.
    • Potential for device damage: All screws must be removed before you begin this step. Do not forcefully pry apart the motherboard with screws still in it because you may damage it.
    • Carefully pry off the motherboard with an opening tool.
  11. Besta Super 5000 Motherboard Replacement: adım 11, 1 resimden 1.
    • Take the motherboard out of the body frame.
  12. Besta Super 5000 Motherboard Replacement: adım 12, 2 resimden 1. Besta Super 5000 Motherboard Replacement: adım 12, 2 resimden 2.
    • Lift the black keyboard mat off of the motherboard.
    • Replace the motherboard.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Jessie
370 İtibar
3 adet Kılavuz yazıldı
Ekip
Ohio State, Team 1-5, Buehl Fall 2014 Ohio State, Team 1-5, Buehl Fall 2014 üyesi
OSU-BUEHL-F14S1G5
4 Üyeler
4 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 17
Her zaman: 374
