Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Have someone hold the bicycle and handlebars steady throughout the fix.
Roll back the brake hood cover on one of the handlebars.
Pop out the bar plug at the end of the handlebar.
Peel off the old handlebar tape entirely.
After removing the old handlebar tape, the old electrical tape securing the brake cables will be revealed.
Remove the old electrical tape if it is not satisfactorily securing the brake cables.
Apply new electrical tape to secure the brake cables.
Cut one two-inch strip of bar tape from the roll, or use one of the two short strips found in the handlebar tape kit.
Peel off the adhesive backing of the two-inch strip and affix it to the handlebar behind the brake lever clamp.
Peel off a few feet of the adhesive backing on the roll of new bar tape.
Affix the center of the end of the tape to the edge of the drop bar so that half of the width of the tape hangs over the end of the bar.
Begin to snugly wrap the tape up the handlebar, pulling the tape up and over the handlebar toward the bicycle.
Upon reaching the break lever clamp, wrap the tape under and around the handlebar, past the clamp.
Continue wrapping towards the stem, pulling the tape up and over toward the back of the bicycle.
Upon reaching the point at which you would like the bar tape to end (typically a couple of inches out from the stem), cut the tape at a steep angle (greater than 45 degrees) toward the end of the bar.
Finish wrapping the last few inches of bar tape.
Roll the brake hood cover back down over the newly-wrapped tape.
Tuck the overhanging tape at the end of the bar into the plughole and push the bar plug back in.
